3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Mod for Picoo Z Mini Helicopter
Step 4Removing the drive gear and bearings
Once the main rotor is removed, the drive gear and shaft can be removed by first removing the small brass collar at the bottom of the shaft. After the shaft has been pulled out remove the two flanged brass bearing at both ends of the rotor shaft mount (shown below being removed with the dental pick). Then push the large drive gear off of the steel shaft. Save the flat washers (2); one is at the top between the drive gear and the brass bearing and the other is at the bottom, between the brass collar and the brass bearing. We'll be re-installing the flat washers into the same positions during re-assembly, but the bushings can be discarded as they will be replaced with the ball bearings.
5 comments
Aug 28, 2009. 7:39 AMmowhawkman290 says:
i dont get what the washer does. im new to rcs
Jan 14, 2007. 4:11 AMzuliani71 says:
Hi, I'm trying the mod but how to remove the small brass collar at the bottom of the shaft. Bye
Jan 15, 2007. 4:53 PMzuliani71 says:
Hi fireball, thanks for answering me, right now I'm fighting to remove the main rotor from the shaft and it's a real nightmare, I'm using your instructions and I've good locking pliers but anyway it's hard to remove. Bye.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
12
Author:fireballxl5(In the bike lane)
I've always been a maker, mod-er, and tinkerer. I started out by taking things apart and then trying to put them back together.
