Mod-mikeydwg "minigun"
Published
Introduction: Mod-mikeydwg "minigun"
About: I like building knex guns and modding nerf guns. I play Call of Duty and Minecraft. I also own a minecraft server.
First off, if I get tons of haters, this is my last Knex gun build. I don't think anyone cares, and neither do I. It is as simple as that.
Step 1: Main Part
For the barrel and trigger, attach yellow connector then green then yellow then green onto two yellow rods (1). Then make one of (2) and slide it on through the hole. Then yellow connector then green then yellow. Then one more (2). Then one more yellow and a diagonal grey.
Step 2: Adding the Handle
Add three green rods to the front three connectors. Place a orange connector on all of them and snap a white connector on the bottom.
Step 3: Linking the Trigger and the Ammo Lock
The second trigger looking piece keeps the bullet from falling out the tip. Link it up using a yellow, white, or orange connector to the crappy trigger. Use a white rod on the bottom as one trigger.
Step 4: Ram
Use a yellow rod and 1 tan and one grey connector. Use rubber bands and green rods to adjust to desired tension.
Step 5: Loading and Firing
To load, begin pulling back the ram and load a green rod as ammo when the ram is far enough. Tip the gun back so the ammo will fall back. Make sure it is in between the two lever like parts. When it is, flip the gun horizontally and continue to pull the ram back. Slide trigger down to lock ammo inside. Pull back up to fire.
When I get on the computer I will add notes to the pics to help.
    • Oil Contest
      Oil Contest
    • Stick It! Contest
      Stick It! Contest
    • Pets Challenge
      Pets Challenge
