Unfortunately if you don't use your keyboard for some time your battery discharge rapidly.
So i decided to insert a power switch and a LED indicator to save battery life.
What you need:
- screwdriver
- scissors
- drill
- soldering iron
- electric cable
- little electric switch
- LED (i used 3mm diameter)
- 470 ohm resistance (depending of the type of LED used)
Remove these ads by
Signing UpStep 1: Removing screws
Remove them and remember their position (the screws are not all equals)
Visit Our Store »
Go Pro Today »
May be you can measure the current by a ammeter,and if it is below 10uA,there is absolutely no need to insert this switch.
If your battery is 800mAh,with 10uA current ,there will be 80000 hours for the battery to be totally discharged.80000/24=3333days=~10 years.
Even if the current would up to 100uA,there will still be about 1 year.
And maybe that is why the manufacturer didn't add a switch.
In my opinion,don't turn the switch rapidly.Because there will be a peak current the time it turns on.And it is a waste of power rather than saving.
I don't know if there is a peak current or not when i turn it on, but now my keyboard is working from months with the same batteries.
Well done mod. Well done indeed :).
My keyboard is almost identical to laurentio's, but it has a button just below the mouse ball for said purpose.
Still, it is odd why they would release this keyboard in the first place...
