3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Mod your mouse:LED color
Hi, don't you thing that is red color of mouse already boring? You look for something modern, and dark-great look? Wellcome!
Note: Meabe there is already Instrucatble like this, but here is my version.
Step 1Parts, and let's start
Parts, and let\
Parts and materials:
*Optic computer mouse
*Screw driver
*100mcd 20mA blue LED
*Soldering iron
*Solder
So, when you have parts and materials, start workin'. Open your mouse(there is usually just one screw), remove wheel and cable.
10 comments
Jan 18, 2010. 12:15 PMlemonie says:
How well does this mouse work? You're at the opposite end of the spectrum to that at which it was designed to operate.
L
Jan 18, 2010. 1:23 PMfrollard says:
I've done lots of led mouse mods -
red is one of the best by default; but most all work -
infrared, (really neat, 'invisible),
blue (works good on jeans, terrible on dark surfaces),
Green, not so great,
UV - works great on anything uv reactive, terrible on anything else.  Surprising that some dark surfaces work awesome when they make no visible reflection.
White - pretty awesome.
Remember you may need to change an led on the board if you change colours - blue and white take more voltage than green red yellow.
May 26, 2011. 2:23 PMharvie says:
I've just made stealth ninja IR mouse :-) Used cheap dealextreme IR LED (20 pack for ~ $2) and works without problem. I hope i will not miss the visible light in dark times :) Maybe i'll try white LED next time...
It may be cool to have multiple LEDs (or multicolor LED) and be able to choose the color using some switch. Switching between White and IR seems to be usefull (but little bipolar :-)
May 26, 2011. 4:11 PMfrollard says:
Just be sure to add an extra resistor because IR uses less voltage than red, and will burn out quick if you don't protect it.
Apr 20, 2011. 11:48 PMsjoobbani says:
when you say UV reactive, what does that exactly mean? Like different color mouse pads?
I think white, because it 'glows' under UV light right?
Apr 21, 2011. 3:00 PMfrollard says:
'glows' = reacts = uv reactive.
Basically the sensor doesn't SEE uv, but if the uv hits something and it floresces a visible colour (like the bright purple or green that comes off various surfaces), the sensor will see it.
Sep 7, 2010. 7:41 PMxxjackxx says:
I just modded my Labtec mouse and green works pretty well for me.
Jan 18, 2010. 2:10 PMlemonie says:
Which is why I asked.
L
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
12
Author:dava_2(e-radionica)
Hi everyone! I'm David, coming from small city in (also) small country called Croatia. I'm attending 2nd class of secondary school. I am running a local DIY site which also sells components all over ...
more »
