Modded Xbox incorporated into a Scion TC
 by richiehops
Featured
This project is not for the procrastinators who are faint hearted.
In doing this project the DIY'er holds all responsibilty for any type of damage. Whether it physical, mental, or property.
The brain of the project is a Xbox softmodded with linux running XBMC (Xbox Media Center) and a 250gb hard drive. There will be no section in this tutorial on how to softmod or instal XMBC on your Xbox. There is more than enough information already out under that subject. This project will show how you can take an Xbox and have the on/off, eject/close buttons, and the dvd drive in the center console for your convenience. It seems like a silly idea but imagine carrying your entire itunes library and any shows or movies you would like to watch on a long drive (as long as your not driving, Dangerous!!).
In this project I handled all the hardware situations but the software installations was all my friend BJ (so thank you, sorry missed halloween)
Step 1: Opening the Xbox
First we will open the Xbox and get comfortable with what lies inside. To see how to open the Xbox LLama.com or Xboxscene have excellent tutorials. After opened use Xboxscene to decipher which version the box is. If you have V1.0 to 1.5 you can use Sickmods.net's atx to xbox psu converter.
I unfortunately did not have version 1.0 to 1.5 so i do not know exactly how to but you can use the converter to take the power from the car (12v) and use it to power the xbox directly. I had to use an old fashion inverter, which isn't bad but it would of made the project so much cleaner, more built in, if you will.
Well this is what my boxed looks like now. Pretty simple stuff. The bottom left is the two inputs for the 4 controller ports. Top right (bigger box) is the Ide cable which I kept as the flat ribbon style. I definitely think it is possible to get the rounded type of Ide cable for this project but I have not tried it. The small top right box is the power to the dvd drive, incredibly small wires. The mid right is the fan which I thought I should keep in there since it will be under a hot seat with not a whole lot of ventilation. The big middle box is the power cables to the hard drive, pretty self explanatory.
Step 2: Layout
Before you extend the wires or get busy buying wire you must figure out where the items will be setup. You can literally put any item anywhere you would like, given functionality and style, except the Ide cable. The Ide cable has a limit on how long it can be while still functioning correctly. I bought my custom cable from stone wall. Order a cable with the longest distance being from the motherboard to the hard drive because then you can tuck the hard drive under the carpet or anywhere incognito. Unless your seat is high enough to house the Xbox with the hard drive in it. You should figure out where you want the dvd drive and the Xbox, make sure it is not more than 48 inches and somewhere in the 48 inches plan where to put the hard drive. Anything else can go wherever you would like. Ports built into the console or in a cubby in the car. Whatever you want but be creative and buy a dremel to make precise cuts.
Don't Forget: This picture does not included the A/V cable.
Step 3: Modding the car
Now that you have fiugred out how the Xbox will lie in the car. Where the dvd drive will pop out from and where the hard drive and controller ports will stay out of site. It is time to measure twice and cut once. Measure the place for the Dvd drive make sure it fits. If cutting needs to be applied be careful and make sure measurements are accurate and that the ide cable will reach that far with the hard drive attached. Take out any necessary parts like the center console, seats, glove compartment, stereo, molding, and anything that could hide wires or any hardware. In the TC I took out the cenbter console by taking the shifter top off. Then prying up the piece of plastic that attaches to the boot and don't move it too fast because there will be a wire to unhook.. Then the cup holder piece and finally the stereo piece. Then unscrew the two phillip head screws. Then in the bottom of the center console cabinet is two bolts. When bolts are removed Put the stick shift in the farthest position to the back. Also undo The console is a power cable for the power outlet, undo that. Take the farthest back part of the console and pull towards the rear of the car. When it comes away from its screw spots in the front just remove carefully out the door. Probably have to trim a bit of the front corners for the dvd drive opening. Just measure and be careful with the dremel.
Step 4: Tedious Work.
Alright everything has its place but no power or information to make it work. This is the part that I messed up on and you can improve. I used single wires for each individual wire of each individual piece in this project. All you have to do is find out how many wires one cable has and find cable in Home Depot or Lowes or the Internet with that many conductors in it. Not too thick though, try to match the gauge. Cut a wire at a time and solder it. Keep doing this until all the wires are the lengths you need to fulfill the projects demand.
At this time you should also be waiting for your ide cable to come in the mail.
Now it is time to cut the Xbox down to size (only if your seat can not accommodate the height of the Xbox). Remove everything such as the mother board and the tin if it comes off. I had trouble removing mine.
I chopped the Xbox at the point of the middle of the vents. I cut the tin inside but be careful it sharp. Wear some gloves if you can. With no hard drive, dvd drive, buttons, or usb ports. You can chop it down tremendously.
When it is all said and done should fit quite nicely under a seat in your car.
Step 5: Removing items for work room
The seats, center console should be removed, and anything else in the way that could hide wires or objects. The seats in my car was five bolts. Three in the back covered in two plastic pieces that pop right off. Take the 5 bolts out and tip back the chair, but do not pick up. There should be a couple of wires to undo. Undo them and fold the chair up and carefully remove it.
Step 6: Finishing up
Wires and controller (if thats what you want) are tucked away. Buttons are in place and tight. The power is hooked up and all the cords are plugged into its respective place in the motherboard. Now start it up. Does the xbox logo come up and then the Microsoft under xbox pop up? If it doesn't and the lights are flashing red. You may have not connected the a/v cable. If you get that far and an era code comes up. Google the era code and it will tell you what is wrong. Then fix accordingly. If you are running normal xbox I hope your game, dvd, or cd played. If your are running XBMC I hope the home page popped up. Congrads on a ridiculous (in a good way) project.
Step 7: Transfer Files.
This took me forever. I used the wireless router for xbox but that sucked and the speed was unbelievably slow. So I just bought a long Ethernet cable and plugged one end into my router and the other end into my Carbox. I downloaded FTX which is a program that can manually connect you to a computer. In XBMC set the network connection to static and put in the address and port number, name and password. Remember them and then put them up in FTX and do connect. It should show all the drives on the hard drive. It is as easy as taking a file, be it a movie, music, or show and dragging it over to the xbox drive you desire. Also with the dvd drive You can burn dvd data disks of music and play 4gb of music off of that or even transfer the music from the dvd to the xbox hard drive.
Video
invalid movie: , {width:425, height:350}
1-40 of 65Next »
Irock148 says: Mar 28, 2011. 2:26 PM
YOU HAVE THE RED RIGN OF DEATH!!!!!!!
EVERYONE RUN FOR THEIR LIVES!!!!!!!!!!!!!!!!!!!!!
TheRealDutchOwner in reply to Irock148Oct 12, 2012. 1:35 PM
Fail, this isn't a Xbox 360...
Gostin in reply to TheRealDutchOwnerOct 25, 2012. 2:06 PM
Really? This is a fail? it's the original Xbox.
lonerayven says: Aug 25, 2011. 8:56 AM
I think I'm going to do a classier version of this mod in a scion XB. Anyone want to fund the research? :P Just kidding. I do have a serious lot of ingenious ideas for my XB, maybe ill just be that guy on instructables.
Royse9808 says: Mar 19, 2011. 6:59 AM
thats cool but did it destroy some of the car parts though
LennyTheDub says: Jan 2, 2011. 7:58 AM
Just wondering where you are? Just curious about effect from the climate? I'm in Canada, so hot and humid in the summer and freezing in the winter.
ArkAngel762 says: Oct 7, 2010. 6:49 AM
You didn't need a power converter for the Xbox. Most gaming systems actually use around 12v of power. Instead of spending the extra $50, you could have just found the inverter that is inside the xbox case and disconnect it. Then run the 12v from the Xbox to a regulator then to a fused line to your battery.
ArkAngel762 says: Oct 7, 2010. 6:46 AM
I've got a '95 Chevy Astro which I have converted into at "Shagin Wagon" and this modification is great. It's a rolling box of awesomeness. What the cool part is is the fact that I also have a projector set up so when I press a button in the front console, the rear window opens and I can project up to 112 inches of awesomeness onto anyone's wall (or on the side of a tractor trailer :))
waffleman says: Dec 19, 2009. 2:56 PM
you should try this with a 360 and try to somehow connect it to live. or even try to connect this one to live. your choice.
ArkAngel762 in reply to wafflemanOct 7, 2010. 6:43 AM
To connect a moving car to live, you would need to get a Verizon or ATT 3G USB router on a laptop and bridge the connections. The thing is, if you're out of cell phone tower range, no Live for you. BUT, if you wanted to, you could get a WiFi reciever for your 360 or PS2 and if you are on the road and stop at a WiFi-enabled hotel/motel, you'd have a nice little system. (no guarantee that the network would be able to handle that though. Might want to use a laptop or PC and see what the network settings are)
crc09 says: Feb 4, 2010. 6:48 PM
any tips for doing this for a ps2??
ikirt says: Nov 29, 2009. 4:48 PM
 Just wanted to add that you can also use USB sticks to transfer data to your xbox's HD or play media right from the USB stick.
cornboy3 says: Apr 22, 2008. 9:49 AM
I am so going to do this in my VW Van except geekier!
abadfart in reply to cornboy3Nov 26, 2009. 6:59 PM
i am getting a mini van so that we are more comfortable when we visit family in new mexico "im in NE colorado" and this would be perfect to put games on but i might do it with a modded 360
sashadalton43 in reply to cornboy3Jan 21, 2009. 9:10 PM
thats the spirit!
gwolff says: Feb 3, 2009. 10:25 PM
I have a Scion tC.. if i had enough money,and didnt care about damagin my car forever, i would totalllyyy do this
abadfart in reply to gwolffNov 26, 2009. 6:56 PM
you just don't have enough experience at modding your car  i have put so much stuff where it shouldn't be in cars and trucks
Kuhan says: Sep 24, 2008. 7:54 PM
hahaha the diagram is hilarious!
fjkl; in reply to KuhanSep 27, 2009. 8:20 PM
I keeeeel u! lol!
N1CK4ND0 says: Apr 22, 2009. 4:13 PM
nice ride!
beauwalker23 says: Mar 18, 2009. 3:19 PM
This is so cool! im deff. going to do this with my old nintendo 64, but a bit softer mod if you know what i mean :]
viper2788 says: Jan 24, 2009. 2:04 PM
what do you have under the hood? or any other mods?
btop says: Nov 12, 2008. 1:15 PM
You are my hero. I wish I had a car... Mobile LAN party's!
sashadalton43 in reply to btopJan 21, 2009. 9:09 PM
thats the life!
MJTH in reply to btopJan 1, 2009. 9:40 PM
Mad Idea.
Shinta786 says: Jan 2, 2009. 11:02 AM
ow, and ONe question. how did you connect audio? I have a BOSE surround in my car. 6 side speakers, one front, one woofer, 2 tweeters.....and I would like to have REAL surround in the car like the surround I get when listening to a CD or watching DVD. With the XBOX, there is only R+L. Do you know any program/device which can create a real surround sound? right now, all speakers make the SAME music, it would be nicer if I could control sound like in a game. Imagine a racing game and there is a car behind you, then I would like to hear the car behind me and in front of me when it passes me by. Is it possible to do so, or does it also depend on the game? Probably a stupid question, but I was curious.
richiehops (author) in reply to Shinta786Jan 11, 2009. 7:45 PM
My head unit pretty much does all the work. It does the surround sound on it's own.
Shinta786 says: Jan 2, 2009. 10:55 AM
Incredible......you actually did what I did (almost). I also have EvoX and XBMC on my Xbox. Xbox under passenger seat + slim PS2 built-in in dashboard, buttons separated and in front console and DVD loader in armrest. My inverter is in the BOOT. But still....I also love it. I am planning to put Linux on it and then put some navi-prog on, but.....then I wondered.....what about a laptop under the driver seat. So thats whats gonna come now. Laptop + touch screen with NAVIGATION on linux (somehow). Wish me luck, you also did a VERY nice job.
DIYDragon says: Nov 12, 2008. 4:29 PM
I can see you making lots of gamer friends wherever you go. haha! Cool project though!
elheffe says: Oct 5, 2008. 1:38 PM
I am assuming that you already had the screens put in.. nice mod! would love to do this as it is a dream to make a carputer or something to keep the kids entertained... well, just one kid now and hes 19 months, but still... always plan for the future! :D
DannyboyINXS says: Jun 29, 2008. 11:43 PM
ahahahaha you spend weeks on this and when u start it all up u get this red ring of death ahahahaha it would make it even funnier if the steering wheel had the lit ring lol
Spartan Phalanx in reply to DannyboyINXSAug 9, 2008. 12:46 PM
The regular XBOX can't get the RROD
DannyboyINXS in reply to Spartan PhalanxAug 9, 2008. 10:20 PM
yes, i know that, but i thought that this mod wasn't based on the regular xbox at the time.... obviously i was wrong
smmiller506 says: Dec 29, 2007. 5:02 PM
you need to be careful when undoing the bolts holding the seat done. when you put them back in, you need to make sure they are torqued to spec, or else scion could decide to void your warranty and the insurance company can void your claim if you are in a crash. nonetheless, still very cool. i am thinking about doing something like this, except, i want to use a true computer like a mac mini or a micro pc or small linux box. have it control all of the sound and the controlling device be a seven inch touch screen
Spokehedz in reply to smmiller506Mar 25, 2008. 7:58 AM
I am thinking that the other non-certified electrical work would be an easier claim than non-properly torqued bolts.
Self-Serving Martyr says: Mar 14, 2008. 3:48 AM
Can it still play games?
frosty1433 says: Dec 16, 2007. 7:34 AM
it would be sooooo cool if you could get each player on a different screen instead of having split screen on a tiny display.
richiehops (author) in reply to frosty1433Dec 16, 2007. 3:07 PM
I thought about that but spent so much time doing everything else was exhausted to research it. If you have any ideas how to let me know.
frosty1433 in reply to richiehopsDec 19, 2007. 12:21 AM
well, you could go by a new xbox for each screen for $20 each, if you're lucky... and only play network connect games? that might be too much though...
richiehops (author) in reply to frosty1433Dec 19, 2007. 8:53 PM
yeah thats a bit much..
1-40 of 65Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
