Step 3Modding the car
iImage Information
Now that you have fiugred out how the Xbox will lie in the car. Where the dvd drive will pop out from and where the hard drive and controller ports will stay out of site. It is time to measure twice and cut once. Measure the place for the Dvd drive make sure it fits. If cutting needs to be applied be careful and make sure measurements are accurate and that the ide cable will reach that far with the hard drive attached. Take out any necessary parts like the center console, seats, glove compartment, stereo, molding, and anything that could hide wires or any hardware. In the TC I took out the cenbter console by taking the shifter top off. Then prying up the piece of plastic that attaches to the boot and don't move it too fast because there will be a wire to unhook.. Then the cup holder piece and finally the stereo piece. Then unscrew the two phillip head screws. Then in the bottom of the center console cabinet is two bolts. When bolts are removed Put the stick shift in the farthest position to the back. Also undo The console is a power cable for the power outlet, undo that. Take the farthest back part of the console and pull towards the rear of the car. When it comes away from its screw spots in the front just remove carefully out the door. Probably have to trim a bit of the front corners for the dvd drive opening. Just measure and be careful with the dremel.
