3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Modding Stock Nerf Darts
  • H:\DCIM\100HP315\IM000712.JPG
  • H:\DCIM\100HP315\IM000717.JPG
This instructable will show the proper way to mod stock nerf darts to be better.
Step 1Materials
Materials
Get these:
Pocket knife
nerf dart
glue gun
airsoft bb
75 comments
1-40 of 75next »
Nov 26, 2007. 3:16 PMbiggunner says:
where did you get that 20 shot machine gun and is it a nerf.
Jul 9, 2010. 10:14 AMseabananers says:
it's the AS-20 it's at zellers and it is nerf
Dec 29, 2010. 9:33 AMjames4 says:
i have1 too
Apr 29, 2008. 8:00 PMcool! says:
I had a rapid fire a while back, currently broken, the trigger snapped in half!
Feb 27, 2010. 9:38 AM~Z~ says:
You haz the rapidfire AS-20 too? I barely see any people who haz it. I'm the only one in my school who has it.
Feb 12, 2010. 11:30 PMGh{O}sT says:
hi
Oct 31, 2009. 2:41 PMblayton10 says:
 hi
Oct 3, 2009. 9:15 AMmattmonkey99 says:
Does it add more range? If so how much?
Oct 6, 2009. 4:49 PMElectroinnovation says:
I haven't tried these types but ones similar add about 30% range to stock streamline darts.
Apr 17, 2009. 12:29 AMcool aclaim4 says:
dis is good because I can never find any streamline darts for my recon
Feb 21, 2009. 1:49 PMusnavyseals199 says:
What a great idea! And to think I was about to buy a bunch of darts for my gun. These work with the N-Strike models, correct? Because all the others just jam when you try and fire them.
Feb 21, 2009. 1:48 PMusnavyseals199 says:
This is a great idea, and to think I was about to buy a whole bunch of new darts for my gun! These work on the N-Strike models, correct?
Sep 23, 2008. 8:50 PMbar1ow111 says:
what gun is that?
Feb 1, 2009. 2:38 PMAklash, The hunchback says:
i dont know about the wildfire but it is not much like the tommy 20 except for it being a machine gun. the rapid fire 20 you have to pump a lot but it works quite well.
Aug 28, 2008. 7:12 PMPOTT PIE says:
does it work in all guns??
Dec 17, 2008. 8:07 PMenaris says:
Depends... I modded my recon to accept most ammo, but it should be about the same length as a normal dart (from tip to base) as a streamlined for best effect in any of the bolt- action nerf guns- longshot and recon, as the retaining switch at the front is what pushes the dart into the barrel. You can lose air pressure if its too short, and it wont go as far.
Sep 17, 2008. 5:59 PMfazizal says:
i have one that does type in long shot i should be the first one it better than this one
Dec 17, 2008. 8:05 PMenaris says:
Just a suggestion, but the bb step is easier if you keep the little blue column on the tip (or black or white, depending on the dart) in place, but cut it shorter, and glue it in... its about the same weight as a bb, and itll stick easier. Also, it's recycling mats you already have!
Dec 7, 2008. 10:28 AMclemsonguy1125 says:
is foam backer rod called foam backer rod at lowes
Apr 3, 2008. 12:06 PMgrunter says:
wtf is fbr
Apr 4, 2008. 10:17 AMgrunter says:
thanks
Dec 2, 2008. 1:48 PMbylerfamily says:
What is that picture supposed to mean??????????????????///
Oct 26, 2008. 3:01 PMTom Buckey says:
what does it do to the dart ??????? i dont get what it does ur simply putting a bb inside it
Oct 29, 2008. 12:20 PMTom Buckey says:
oh thnx kk
Aug 27, 2008. 5:37 PMPOTT PIE says:
How well does this dart work??
Jun 21, 2008. 8:35 PMmind13 says:
I use crayon.if you use 1/2 inch long crayon in the darts you shouldnt need hot glue.
Aug 25, 2008. 1:07 PMkiller324 says:
im the drumer for disturbe
Aug 25, 2008. 2:45 PMmind13 says:
Im not shot I beleive that considering the name of the band is spelled Disturbed
Aug 25, 2008. 1:08 PMkiller324 says:
its good
Aug 25, 2008. 1:03 PMkiller324 says:
[[Video(part of me, {width:425, height:350})]]
Jul 6, 2008. 10:40 AMctknex1000 says:
it works awesome in my tech target gun
Mar 8, 2008. 2:02 PMclay10wright says:
does any one know hot to mod a n-strike recon cs-6 not the longshot the new one it is yellow and has a gray pull back clip. please and thank you!!!!!!!!!
1-40 of 75next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
6
Author:nerfer192
