Model Railway DCC Arduino Wireless Commands on a Dead Rail System
1,942
12
42
Posted
Introduction: Model Railway DCC Arduino Wireless Commands on a Dead Rail System
Further to my previous Instructable on a wireless DCC control of a garden train, I have developed a method of wireless transmission of DCC packets from a Command Station to allow dead rail control of locomotives. The basic design is covered here on the circuits and Arduino coding required. The circuits fit into 'G' garden scale locos. However, I leave it to the reader to develop this system into a smaller size for mounting into HO / OO scale trains.
The system was originally developed using the uRF328 (Arduino Uno with wireless). The nRF24L01+ along with an Arduino Mini Pro provides a cheaper option, therefore the system has been adapted to use these modules.
Download the Arduino driver for nRF24L01 http://maniacbug.github.com/RF24
Step 1: DCC Packet Transmitter
Components:
Arduino Mini Pro
nRF24L01 wireless transceiver
SN754410 H-bridge
DC regulator 5v output
DC regulator 3v3 output
Rectifier diodes 1N4001 (2off)
Resistors 10K and 4K7
Capacitors 22uf, 3.3uf, 3.3uf
The circuit above, is the transmitter. A pair of resistors reduces the input voltage to acceptable levels for the Mini Pro. I used the 5volt version of the Mini Pro. The 3.3v version may be used which would eliminate the need for a 5 volt regulator. The Arduino code is based on great work done by Geoff Bunza in the Model Railroad Hobbyist Magazine forum.
The loco commands are extracted from the DCC signal. The packet data is therefore isolated from the signal and transmitted as digital instructions to the receiver via the nRF24.
// nrf24 - transmit DCC data 4 Oct 2016
#include "SPI.h"
#include "RF24.h"
#include "NmraDcc.h"
//Settings
int msg[1];
 RF24 radio(9,10);
 const uint64_t pipes[2] = { 0xF0F0F0F0E1LL, 0xF0F0F0F0D2LL };
 NmraDcc  Dcc ;
 DCC_MSG  Packet ;
 struct CVPair{
  uint16_t  CV;
  uint8_t   Value; };
void setup() {
    radio.begin();
    radio.openWritingPipe(pipes[0]);
    radio.openReadingPipe(1,pipes[1]);
    radio.stopListening();
  Serial.begin(115200);
// Setup which External Interrupt, the Pin it's associated with, disable pullup.
  Dcc.pin(0, 2, 0);
// Call the main DCC Init function to enable the DCC Receiver
  Dcc.init( MAN_ID_DIY, 100,   FLAGS_DCC_ACCESSORY_DECODER , 0 );
  Serial.println("Ready");
void loop(){
Dcc.process();
extern void notifyDccMsg( DCC_MSG * Msg ) {
 if( ( Msg->Data[0] == 0 ) && ( Msg->Data[1] == 0 ) ) return;  //reset packlet
 if( ( Msg->Data[0] == 0b11111111 ) && ( Msg->Data[1] == 0 ) ) return;  //idle packet
String s1 = String(Msg->Data[0], DEC) + ",";
String s2 = String(Msg->Data[1], DEC) + ",";
String s3 = String(Msg->Data[2], DEC) + ",";
String s4 = String(Msg->Data[3], DEC) + ",";
String theMessage = ("DD," + s1 + s2 + s3 + s4 + '\0');
  int messageSize = theMessage.length();
  for (int i = 0; i <= messageSize; i++) {
    int charToSend[1];
    charToSend[0] = theMessage.charAt(i);
    radio.write(charToSend,1);
Step 2: DCC Packet Receiver
Components:
Arduino Mini Pro
SN754410 H-bridge
Step up module 5v to 3v3 (or 3v3 battery)
Step down module 5v to 12v (or 12v battery)
Capacitors 220uf, 220uf, 100nf
The receiver decodes the wireless signal and extracts the loco instructions. These instructions include all DCC command data for loco ID, speed and various functions. The instruction data is combined with the DCC command clock that runs on the receiver Arduino Mini Pro. The output from pin 6 and inverse output from pin 5 provides the input for the H-bridge.
Update 4 Oct 2016:
To decrease processing time, the Arduino code has been modified and now only accepts one loco address in line 36 (int locoAdr = 3).
The use of preamble + 3 bytes or preamble + 4 bytes (depending on DCC Command station in use) must be entered into line 53 { { locoAdr, 0, 0, 0, 0, 0, 0}, 3} // enter 3 for 3 byte and 4 for 4 byte
I have not been able to complete this automatically in the Arduino code as yet.
Also, I have removed the 'printf' functions and other radio functions not required and the speed is a lot better.
Update 13 Jan 2018:
I have added another option for the Arduino sketch to be used on the Receiver side.This option assumes systems with 4 data bytes only. File name nrf24_rx_dcc_4byte.ino
This sketch also includes a faster switching of the DCC output by avoiding 'digitalWrite()' operations.
The nRF24L01 internal supply is very unstable and a 220uf capacitor must be connected across the +/- supply pins.
I have used one pair of the SN754410 H-bridge, the load capacity may be increased by connecting the other pair in parallel.
By using a suitable set of LI-Poly batteries to provide 3v3 and 12v supplies, the step up and step down modules may be eliminated.
  • hello BillI redid yo...-Martinkirkby
    Martinkirkby made it!
  • Epilog Challenge 9
    Epilog Challenge 9
  • Sew Warm Contest 2018
  • Paper Contest 2018
    Paper Contest 2018
1 Questions
Hello Bill
I managed to shrink it down to “mini pro size” however when I used a 3.3v mini pro I could not get it it work? It uses a 8MHz crystal should that make a difference to the timers?
Also I used a smaller nRF 24 which by “happy accident “ I discovered runs on 5v, just need to add the h-bridge to my adapter pcb and that should finish it off nicely.
4DB7288B-1609-48F7-BD07-F38E534671A7.jpeg303084C3-1D37-41A4-9D53-EFDF4D8EB887.jpeg2A36C777-134A-42D0-B916-8D586E666723.jpeg
Hi martin, good work. Why not use the 5v version of mini pro ? The timers are affected at 8Mhz. There is no pre-scaler (/4) for 8 to 2 Mhz as far as I know. Not sure if other adjustments would work at 1 MHz (rescaled 8Mhz / 8), I will look into this and get back to you if I do find a way round this.
23 Comments
hello Bill
Looks like it's just you and me getting excited about DCC over wireless, once again thanks for making it happen for me.
I think there is a fear of the small LiPo battery's etc, my "on track " charging circuit means that the battery becomes a "fit and forget" part of the equation when running with other locos on a DCC powered track and with over 2hours of running time with a converted Hornby OO gauge steam loco with no track power at all.
Yes it's day to day job is pulling the track cleaning unit, that's until we can get the other 50+ locos converted.
Still on the bench with Geoffs loco decoder, pin 6 to 2 showed no sign of life?
I hope you still think it was a good idea ;)
Thank you again
MartinK
Hello Simon
I see Bill and I are not alone ;) yes I follow the site you have linked, always looking for inspiration!
The rise of Arduino has offered one possible alternative to RC/battery Locos, we use them mainly as DCC Accessory decoders (for servos LEDs etc) also for S88n 0V detectors but if like Bill I can fit one in a loco along with a DCC Decoder I get a DCC WiFi/battery Loco.
Geoff Bunza has done many great Arduino/DCC projects and I will continue to develop them hopefully using Bills DCC WiFi code.
As for Bluetooth it’s looking expensive and without a DCC bridge it’s a dead end, most users like their “hand set” it’s usually the thing that decides which system they buy, like most tech they only use 20% of the features and here in the UK I really do not see the other 50% of the users ever moving to DCC at all! So the manufacturers are not looking to the UK for inspiration.
Thanks again for taking the time to post.
I am in the U.K. as well.
The best handset I have is the one I just bought from Tam Valley, for their now defunct DRS. If I can get that to “drive” a base system, I will be happy.
hello Simon
Yes I have x2 of the DRS1 Rx loco chips fitted, I was not aware that they could be controlled directly with a handset? Mine are connected to the DCC bus via their Tx unit. It was a fit and forget experiment due to the cost of each Rx pcb also it was one way comms so a bit of a dead end for RailComm etc
Bills Tx and Rx/H-Bridge Arduino’s work out much cheaper per loco and I like the way he has stayed with DCC as the command system, little chance of that disappearing any time soon!
Just got to get it all “slimmed down” to SMD size ;)
I have upgraded 2 of my garden trains with the wireless DCC system. So yes I do think it was a great idea from you Martin. The old LGB loco needed a more powerful battery. I am currently using a small lead-acid 12v battery from an alarm system. It sits in a modified truck along with the Arduino circuit. This is much easier in these large scale trains of course. I agree, the Li-Po batteries are a bit scary for some. I use the Li-Ion type in my diesel engine which has space under the floor to house them.
hello Bill
You are going to have to help me out here, are you transmitting all the NMRA DCC or just the speed values?
I have loaded your latest receiver version which is comparable with your new DCC command station according to your latest post but I can not get the F1 etc to function and also the motor control is still slowing above 60/70% power ?
Does the loco decoder need its speed table programming i.e. CV 5 +6 and a Start Voltage CV2? As I am writing this I now feel a little foolish to have not tried it!
As I have Geoffs Mobile Decoder on test I understand it does not have a "speed Table" function as it's really just an Accessory Decoder with Servo/Motor control added, so I might just focus my effort on getting a "off the shelf" loco decoder working.
Thanks in advance
Martin
Hi Martin
I think I may have confused you with my last reply. Are you using the 'DCC packet Transmitter' and 'DCC packet receiver' circuits as shown above? If so, the Arduino code in this intractable should work as it is simply taking the DCC commands from your Command Station and transmitting the complete DCC data (including functions). I was using a Bachmann and a Compact (Atlas) DCC command stations which both work fine. Maybe your system uses 4 bytes (plus preamble). I have included this option in the code but I have not tested it. The Arduino code in my new intractable is not relevant to the above circuit - sorry if I misled you. Maybe you could send me a copy of your circuit diagrams to let me understand what you are doing ? billc.c@btinternet.com
hello Bill
I hope you have enjoyed the garden layout this year, I have your project back on the bench and have it connected via pin 6 to Geoffs mobile decoder (also to a standard DCC loco decoder for comparison via the motor driver IC) the wire link between Arduino mini's needs to be < 20mm (pin6 to pin 2) to work.
All works as expected if the decoder address is set in the code, however the speed steps above 60% do reduce instead of increase? but only on Geoffs decoder.
Have you any progress on the code to make any more of the DCC commands
available ie F1 F2 etc or being able to pass the decoder address via the nrf24
instead of hard coding it for each loco/Arduino?
Hi Martin
Yes, weather permitting, I have run the garden train successfully without the problem of dead spots in the track. Only leaves and twigs spread on the line by foraging birds, need to be swept away first. What a difference the wireless system makes!
Some of your questions are answered in my latest intractable, see:
https://www.instructables.com/id/Garden-Train-Ardu...
On further examination of the speed code required I found an error corrected in the new code within this intractable. A look up table is required to enable the speed steps.
