3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Model Woodworking Board or Sheet Part
Step 17Use Modify Button to make changes in Equation Editor
Select the Modify button (or Alt+M) to modify the current parameter.
Change the Parameter Name to Length.
Change the Parameter Equation value to 12, for a 12" long part.
Select OK to close the Modify dialog box and accept the changes.
Select OK to close the Equation Editor dialog box and return to the dimension box.
HINT: It is important that the current parameter is highlighted when exiting the Equation Editor dialog window! If any other parameter is highlighted, the value of that parameter will be replaced as the value of the current parameter. This is a feature that allows a value of a parameter to be specified by selecting another parameter from the Equation Editor dialog window.
Enter the Equation Editor via the icon or Ctrl+E when making changes to parameters, and avoid making changes to other parameters when using the Equation Editor to specify the value of a particular parameter during dimensioning.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
24
Author:woodknot
I am an Engineering Technician with 15 years as a glorified government drafter. Another 5 years was spent drawing/programing for a company that had CNC machines. I taught AutoCAD at the local communit...
more »
