Model complex solid shapes with cardboard.
This is a technique to model complex (or simple) solid shapes.
The idea is to cut your model into slices and cut cardboard with the shape of your model slices. When staking the slices in the correct order you get your model in rough finish to start sanding.
The final model will have really good weight and resistance. A great advantage of this method it's its precision since the model comes out almost exact as the 3d computer model. A disadvantage is the amount of time you may spend cutting and sanding.
This is kind of a replacement for a laser cutter and MDF plaques. For me it was faster and more controlable than laser cutting MDF. Hope it helps!
In dedication to my design classmates with whom I learned this technique. | Dedicado a mis compaıeros de diseıo con quienes aprendi y sigo perfeccionando la tecnica.
www.combaideas.com.ar !
Step 1Make your 3d model
Make your 3d model
Model your object in your favorite 3d modeling software. You don't need it to be exact, round corners can be later sanded so don't bother to do your model highly detailed.
I use Rhinoceros 4.0.
145 comments
1-40 of 145next »
Jan 22, 2012. 8:41 AMSneyk says:
Excelente, muy útil para realizar prototipado.
Jan 19, 2012. 9:06 AMMike McGill says:
This is very similar to a method that was once known as 'bread and butter' . It was used as an alternative to plank on frame to build hulls for model yachts. You use the lines of the yacht to produce sliices which are hollowed in the middle, and then when they are glued together you carve and sand the outside. It is possible to produce a very accurate hull using this method, because the bottoms of the notches made by the sandwich provide a guide when carving. Must say I never thought of applying it to circular saws though. Nice one !!
Sep 8, 2011. 8:22 PMnotingkool says:
hola, te hago una consulta, estoy queriendo hacer algo asi:
http://www.lasercamm.com/rapid.htm
como lo que hace ese programa, hay algun plug in, o similar para autodesk o rhinoceros?
porque no busco hacer un sanwich de carton para llegar al modelo, sino que busco hacer aglo como esto: http://www.instructables.com/id/Wave-Laptop-Stand-Making-3D-Shapes-in-Ilustrator/
o esto: http://www.londoncyclist.co.uk/wp-content/uploads/2011/06/7e21c18c0b66_E884/kranium-helmet_thumb.jpg
o asi: http://t0.gstatic.com/images?q=tbn:ANd9GcT4cnZfyky_Gm6gdUaB1o7gFccv09wEJ1R7L9vsERGpuZ7-PxMeEw
yo con el autodesk inventor me manejo bien, pero no llego a ahecr eso.
Nov 14, 2011. 7:25 PMnotingkool says:
claro, yo habia hecho algo asi, pero en realidad busco ahorrarme muchisimo laburo. Porque yo corto las secciones con planos y saco las siluetas, depues tengo que hacerle las ranuras, ponerlos en autocad, y despues en un plano para imprimir. Y la verdad, me lleva muchas horas hacerlo para un modelo. Y se me complica aun mas cuando quiero cortar rejillas a otros angulos o poner uno u otra especial en algun lado.
Oct 17, 2010. 7:07 PMSkyriam says:
Does anyone know if SolidWorks allows to slice your model and then print it like Rhinoceros? Thanks.
Dec 9, 2010. 1:20 PMGepetto Father says:
I know i probably am severely late, but yes, it's possible to slice your model in solidworks. Create a sketch in the model with your parting lines, and then use that sketch as a reference to create sections in a drawing. Now you just have to arrange the sections in as many sheets as needed. Last time i did that was for a fiberglass laminating mold, and the model rendered 18 sections, easily printable in the correct scale from the drawing.
Aug 29, 2011. 10:51 AMhalfmumi says:
Can you add any screenshots to help to situation? I am lost a little. :) Thanx a lot btw.
Jul 28, 2011. 7:15 AMjammaconnection says:
Can yiu explain how you make slicing on rhinos? it should be nice! maybe you use rhinonest? I should know how to did it on rhinos
Jul 17, 2011. 8:48 AMononal says:
thank you for this helpful instruction, layering is a really good technique for creating solid shapes.
i may add something that may helpful for shelling with this technique. wooden sticks may be used on layered cardboard, which will be helpful for having stronger shell and sanding model into precise dimensions.
t
Oct 17, 2010. 3:01 PMSkyriam says:
Hey great instructable! Your method is real simple and awesome, just have one question: The "platic putty" you mention, is it PLASTER? The one used for cars? Thanks!
Oct 17, 2010. 4:33 PMSkyriam says:
Ok gracias!! Saludos desde méxico y sigue con el exelente trabajo!
Oct 17, 2010. 10:32 AMTechnophile says:
Thin white glue with water to keep the glue layer thickness down.
Aug 11, 2010. 6:15 PM11ericg says:
Blender is my fav 3d modeling program
May 21, 2010. 4:00 AMmario59 says:
I was thinking a way to properly align the sheets once separated from the printed paper you used to cu them. since the cut borders are always rough since you've to sand them after, do the glue gives you time to make this alignement?
I tried it, but the tholuol is almost like an INSTANT GLUE!
also after brushing it to the sheet, it gets dry almost instantly!
can you be clearer on this?
thanks!
ciao
Mario
Dec 12, 2009. 9:59 AMEvilthingamabober says:
 Wait a sec, did you just make a power saw out of cardboard?
Feb 16, 2010. 7:52 PMEvilthingamabober says:
 Actually, can you post an instructable on how to make the circular saw?
Feb 13, 2010. 10:01 AMstephenniall says:
i thought you were going to use that circular saw to cut the cardboard ! then i realised .. It is cardboard ! Awesome instructable
Oct 19, 2009. 8:54 PMmj_b90 says:
 Has anyone tried doing this in CATIA? I can only get it to export one slice at a time, that'd take forever. Any tips?
Jul 19, 2009. 10:24 AMfull_metal says:
do you have to use 3D modeling software as i only have acces to using 2D software.
Jul 28, 2009. 9:44 AMjptrsn says:
I use SketchUp to do all my 3d modelling - it's free, and it has a function to slice models. Check it out; it might work for you, full_metal.
Jul 29, 2009. 8:52 PMcoretj says:
I downloaded SketchUp but can not find the feature that adds the slices. pls hlp
Sep 15, 2009. 3:59 AMHold_out says:
use google sketchup free 7 and found a free plugin that slices models. The link is below. Just but the file in your plugin folder of sketchup.
http://www.cad-addict.com/2009/07/sketchup-plugins-slice-your-model.html
Oct 17, 2009. 4:37 PMDentroman765 says:
 Thanks! Works pretty well, although the plugin seems to mess up complicated structures sometimes. Can't complain though, I was planning on manually slicing until I read this.
Oct 18, 2009. 11:10 PMHold_out says:
No Problem, good luck with your model.
Jul 30, 2009. 10:44 AMHiroak says:
The slice feature is only available in Google Pro 6.
Jul 15, 2009. 5:19 AMmario59 says:
Grat idea!
I think is *the idea* to make modeller's creations, otherwise very hard to get!
In the meantime, maybe would be a good idea, also, to find a way to get "lighter" objects, to "epty the inner parts in some way (personally I dunno how!)
Also I could not find any indication of how, so many "layers" could be glued together without adding a considerable thicknes from the glue itself...
maybe you have to "miss" some of the slices to compensate it?
who knows?
anyway: congratulations!
ciao
Mario
Oct 17, 2009. 4:29 PMDentroman765 says:
 How about assembling some slices, then dremeling? That might be a good way to get some material out.
Jul 23, 2009. 3:40 AMagis68 says:
yeah actually this is what is called Industrial design and modelling....is a very well paid position or the elite of 3D modelling everywhere in the world
Jul 22, 2009. 6:03 PMbill2009 says:
When I have to do empty shells for models I use sheets of high impact plastic (its a type of polystyrene).
I'm not sure I follow you, how do you use the styrene? Instead of the cardboard?
Jul 23, 2009. 9:53 AMbill2009 says:
Sorry, I'm still not sure I get it. It sounds like that would work best for something with flat surfaces so, for an open sided cube you'd be making 5 surfaces? What about something with rounded corners like a hemisphere?
May 20, 2010. 1:29 PMHonestinwilkesbarre says:
I realize your comment was made a year ago, and you may already understand what this instructable is about.
But.....
Actually, you could make a hemisphere with this process. And a sphere would take just about the same number of slices as a cube (or a box). The problem is your under-thinking it. You don't slice along surfaces, which in the case of an open sided box would be 5, you make dozens (or hundreds or thousands) of parallel slices. Think "Cat Scan". They already have 3D printers that work on this principle.
1-40 of 145next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
23
Author:piaferre(COMBA ideas, design)
Industrial Design student at UBA | Estudiante de Diseño Industrial UBA
