The idea is to cut your model into slices and cut cardboard with the shape of your model slices. When staking the slices in the correct order you get your model in rough finish to start sanding.
The final model will have really good weight and resistance. A great advantage of this method it's its precision since the model comes out almost exact as the 3d computer model. A disadvantage is the amount of time you may spend cutting and sanding.
This is kind of a replacement for a laser cutter and MDF plaques. For me it was faster and more controlable than laser cutting MDF. Hope it helps!
In dedication to my design classmates with whom I learned this technique. | Dedicado a mis compaýeros de diseýo con quienes aprendi y sigo perfeccionando la tecnica.
www.combaideas.com.ar !
Remove these ads by
Signing UpStep 1Make your 3d model
I use Rhinoceros 4.0.
http://www.lasercamm.com/rapid.htm
como lo que hace ese programa, hay algun plug in, o similar para autodesk o rhinoceros?
porque no busco hacer un sanwich de carton para llegar al modelo, sino que busco hacer aglo como esto: http://www.instructables.com/id/Wave-Laptop-Stand-Making-3D-Shapes-in-Ilustrator/
o esto: http://www.londoncyclist.co.uk/wp-content/uploads/2011/06/7e21c18c0b66_E884/kranium-helmet_thumb.jpg
o asi: http://t0.gstatic.com/images?q=tbn:ANd9GcT4cnZfyky_Gm6gdUaB1o7gFccv09wEJ1R7L9vsERGpuZ7-PxMeEw
yo con el autodesk inventor me manejo bien, pero no llego a ahecr eso.
Si no tenes este comando podes encontrar las intersecciones de tu modelo con varios planos que seria lo mismo. Hay muchas soluciones, espero haberte prendido la lamparita jaja saludos!
i may add something that may helpful for shelling with this technique. wooden sticks may be used on layered cardboard, which will be helpful for having stronger shell and sanding model into precise dimensions.
t
I tried it, but the tholuol is almost like an INSTANT GLUE!
also after brushing it to the sheet, it gets dry almost instantly!
can you be clearer on this?
thanks!
ciao
Mario
http://www.cad-addict.com/2009/07/sketchup-plugins-slice-your-model.html
I think is *the idea* to make modeller's creations, otherwise very hard to get!
In the meantime, maybe would be a good idea, also, to find a way to get "lighter" objects, to "epty the inner parts in some way (personally I dunno how!)
Also I could not find any indication of how, so many "layers" could be glued together without adding a considerable thicknes from the glue itself...
maybe you have to "miss" some of the slices to compensate it?
who knows?
anyway: congratulations!
ciao
Mario
I'm not sure I follow you, how do you use the styrene? Instead of the cardboard?
But.....
Actually, you could make a hemisphere with this process. And a sphere would take just about the same number of slices as a cube (or a box). The problem is your under-thinking it. You don't slice along surfaces, which in the case of an open sided box would be 5, you make dozens (or hundreds or thousands) of parallel slices. Think "Cat Scan". They already have 3D printers that work on this principle.
