Step 6Sand, add plastic putty, sand, paint, finish
I recommend you apply some primer before you paint to even the surface.
Practice a few times because it's a technique that gets better with it. Share your experimentations with others. Thanks for reading and the best of luck!
i may add something that may helpful for shelling with this technique. wooden sticks may be used on layered cardboard, which will be helpful for having stronger shell and sanding model into precise dimensions.
t
I tried it, but the tholuol is almost like an INSTANT GLUE!
also after brushing it to the sheet, it gets dry almost instantly!
can you be clearer on this?
thanks!
ciao
Mario
I think is *the idea* to make modeller's creations, otherwise very hard to get!
In the meantime, maybe would be a good idea, also, to find a way to get "lighter" objects, to "epty the inner parts in some way (personally I dunno how!)
Also I could not find any indication of how, so many "layers" could be glued together without adding a considerable thicknes from the glue itself...
maybe you have to "miss" some of the slices to compensate it?
who knows?
anyway: congratulations!
ciao
Mario
I'm not sure I follow you, how do you use the styrene? Instead of the cardboard?
But.....
Actually, you could make a hemisphere with this process. And a sphere would take just about the same number of slices as a cube (or a box). The problem is your under-thinking it. You don't slice along surfaces, which in the case of an open sided box would be 5, you make dozens (or hundreds or thousands) of parallel slices. Think "Cat Scan". They already have 3D printers that work on this principle.
You can also try with modeling epoxy, a few strips of plastic for the skeleton and a mold to copy. That's how I did the other part of the spoon. But you can only get to about 2mm thick and the surface will allways have imperfections.
