3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Model hot air balloon
Here's an instructable that shows you how to make a hot air balloon using tissue paper.
Materials:
- Tissue paper (at least 40 sheets, size 100 x 70 cm)
- glue
- scissors
Step 1Step 1
Step 1
Cut all the pieces in the right size but don't forget to make an adhesive edge.
Dimensions:
http://sketchup.google.com/3dwarehouse/details?mid=d5499071d87f16696b1345249af3ea3b&prevstart=0
(to download sketchup: http://www.google.com/sketchup/download/)
When you open our model in sketchup you can easily adjust the sizes of the hot air balloon.
4 comments
Dec 9, 2010. 5:30 PMrimar2000 says:
Good work!
I can't see the video, as you see in the attached image. Then, I don't know how do you make the glueing. But I would bet that there is an easier way to do it because I devoted myself to these balloons many years ago. I could describe it, without photos, if you are insterested.
Dec 11, 2010. 10:50 AMrimar2000 says:
Yes, this video functions! Thanks.
Dec 11, 2010. 10:46 AMrimar2000 says:
I will try to explain with words, with my "yes, bwana" English, because now I can not get to do a instructable.
Whatever the shape of the segments, provided that they are all equal and symmetrical (as in this case), you must bend longitudinally all them individually. Then stack them so perfectly match the folds on one side and the edges at the other. Then you take a bottle of white glue, the kind that leaves a thin thread of glue, and carefully lift the edges of the above segment and stick to the next segment (under it). Done this, follow down through the stack to adhere one by one (careful not to join both sides of the same segment each other) until the last. At that time, fold the upper half of the first segment 360 degrees, which was loose, and stick it to the bottom segment. Let it dry a few minutes and you'll see that when you open the balloon is fully assembled, with the added booster edge between segment and segment, which are perpendicular to the surface when inflated.
All this chatter seems complicated, but it is very easy and fast to do.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:jeroen144
