Modern 4x4 Off-Roader
Published
Introduction: Modern 4x4 Off-Roader
Even though this build is a good size, it is only 72 pieces, which makes it faster to build! In these next steps, I'm going to show you how to build an out-of-the-box Modern 4x4 Off-Roader. I hope you enjoy!!
Step 1: The Parts
Step 2: Put the Seat Part on the Long Gray Plate
Step 3: Put the Two 2x1's on Either Side of the Plate, With the Horizontal Lines Facing Outwards
Step 4: Put the 2nd Gray Plate on Top of the First Plate, Then Place the Assembeled Piece on the End of the Gray Plate
Step 5: Put Half of the Gray 2x4 on the Slanted Plate, and Cover the Hole With the Other Half. Then, Put the Black Hood on Top of All Those Other Pieces
Step 6: Put Half of the 2x6 on the Plate, and Half of It Off. Next, Put the Special 4x3 Piece on the 2x6 Plate
Step 7: Put the Three 2x6's Across the Gray Plate, Then Put the Two 4x1's on the Perimiter of the Plates
Step 8: Put the Two Special Curved Pieces on the End of the Plate, Then the Slanted 2x1 Lined Pieces on Top of That
Step 9: Put Two Light Gray Plates on the Front of the Flatbed. Then, Place Two Dark Gray Pieces on Each Side of the Perimeter of the Flatbed
Step 10: Put Two Black Lined 2x1's in Front of the Light Gray 2x1's. Then, Put Two Other Black Lined 2x1's Across in Front of the Other 2x1's on the Flatbed
Step 11: Place the Two Orange Head Lights on Either Side of the Slanted Light Gray Pieces. Then, Place 6x1 Above the Black Seats. Finally, Place the Big Window Piece on the Front of the Seating Area
Step 12: Place the 2x6 Light Gray Plate Above the 6x1 With the End Hanging Over the Front of the Flatbed. Then, Place a 2x4 Dark Gray Plate in the Middle of the Window and the 2x6 Plate. Finally, Place Two Light Gray 2x4 Plates on Either Side of the Dark One
Step 13: Put the 4x1 With the Two Missing Studs in the Middle in the Middle of the Roof. Then, Put the Two Orange Head Lights Beside the 4x1. Finally, Place Two 2x1's Behind the Head Lights
Step 14: Place the Twogray Slanted Pieces on the Special Car Part Piece. Then, Place a Dark Gray 2x1 Plate Beneath the Car Piece in the Middle
Step 15: Place the Assembeled Piece Under the Plate That's Hanging Over the Flatbed. (Continued on the Next Step...)
Step 16: Place the Two Slanted 2x1's at the Front of the Flatbed on the Perimiter. Then, Place Two 2x1 Vented Pieces in the Middle of the Flatbed on the Perimiter
Step 17: Place the 2x1 Over the White 2x6. Then, Put the Two Red Studs on Each Side of the 2x1. Next, Put the Orange Studs on the The Ends of the 2x6. Finally, Place the Connecting Gray Piece in the Middle of the 2x6
Step 18: Place the Assembeled Piece Under the End in the Middle of the Flatbed
Step 19: Place the Black Rail Piece at the End of the Flatbed
Step 20: Place the Dark Gray 2x6 Over the Black 2x6
Step 21: Connect the Two Dark Gray 2x4's. the Place the Assemeled Piece in the Middle and Two Studs Away From the Largest Gray Plate.
Step 22: Put the Light Gray Cylinders in the Black Tires. Then, Put the Attach the Wheels to the Connecting Pieces
Step 23: Attach the Wheels to the 4x4 Offroader
    • Oil Contest
      Oil Contest
    • Clocks Contest
      Clocks Contest
    • Stick It! Contest
      Stick It! Contest
