This is a very basic overview of how to make this lamp, inspired by this red one: http://www.instructables.com/id/Universal-lamp-shade-polygon-building-kit/step5/Other-Ideas/
It was a learning experience, and I can tell that some of my choices weren't ideal. However I never got around to coming up with something better, so here you are. Also I made this 2 years ago, it might be a little vague, sorry.
Step 1: Materials
What you need:
Intangible:
-Persistence and creativity to actually get this to work out how you like.
-Some electrical knowledge, or someone who has that, or some sort of kit, or an existing lamp.
Tangible:
-A large, bendable, translucent material that wont melt or burn. I used mylar that I found at the book store near the art campus. I bought it by the foot, and you'll need to figure out how much you need by planning out how you can cut out the pieces.
-Two-way tape or something equivalent.
-Wire - a coat hanger could work
-wire cutters
-a washer
-a socket, light bulb, cord, switch, and chain, soddering tools
ellenjoelle says: Aug 31, 2012. 8:27 PM
Well done, you rock! Thanks very much for taking the time to make the videos and the sketch - despite several years of modular origami I found it hard to imagine what kind of shape would be folded which way.
I will be making this some time soon that is not 4:30 in the morning! :)
louie henderson says: Jan 27, 2012. 7:04 PM
I LOVE This!!! Is there a template for it?
tinasab says: Nov 20, 2011. 2:01 PM
Hello,
this is very nice, I tried it already with paper, just one problem - what is diameter of plastic circle inside which holds the shape of the lamp? As well, is mylar suitable material if e consider the heat from a bulb? Isn't it gonna burn? ;))
Thanks for nice instructable, we are gonna use it in new apartment :)
wearingpink (author) in reply to tinasabNov 28, 2011. 6:31 PM
I don't have it around to check, but I want to say a diameter of about 7". When I made it, the inside piece was a rectangle longer than the inside circumference. It had enough spring in it to push out and form to the correct size.
The mylar is suitable. I looked up melting temp and they all seemed fairly high. Plus, a CFL generates very little heat, so there is not gonna be a problem. And, its really well ventilated anyway.
RabidAlien says: Aug 24, 2011. 10:17 AM
Looks great! I'm thinkin this would make a great desk- or floor-lamp (all of our ceiling lights have ceiling fans attached) shade. How much light does it give off? Enough to read by? Hmmm....adding a couple different colored LED's, I bet one could program an arduino to slowly rotate between colors for a really cool effect....or get a multi-position switch that manually switched colors. Hmmm...possibilities!
Kiteman says: Jan 9, 2011. 5:20 AM
Fitting the pieces together in step 2 is not so clear.
Might I suggest you make another of your paper prototypes. and video how you slot the pieces together?
wearingpink (author) in reply to KitemanAug 22, 2011. 5:13 PM
finally got around to it. Don't know why I was half-assing it so much the first time.
agil2 says: Aug 16, 2011. 1:16 PM
could you upload a template for it? i'd really appreciate it. pretty nice by the way
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
