Introduction: Modern Walnut and Leather Stool | How to Build - Woodworking
In this project, I'll show you how to build a modern Walnut and leather stool. This was a fairly simple build, but I absolutely love the way it turned out. This was also my first attempt at leatherwork and certainly won't be my last. Let’s get started!
Don't miss the video above for a LOT more detail!
Step 1: Gather Your Tools and Materials
Picture of Gather Your Tools and Materials
If you're using 1x2s from your local home center for this project, the only power tools you'll need are a miter saw with depth stop functionality, a drill, and a sander. I used rough lumber, so I used a few more tools to mill my lumber.
Materials Used On Modern Walnut and Leather Stool:
Tools Used On Modern Walnut and Leather Stool:
Step 2: Break Down Your Materials & Cut Parts to Length
Picture of Break Down Your Materials & Cut Parts to Length
This project can be built with 1x2s or 1x3s from your local home center (Home Depot or Lowe’s if you’re here in the United States). I’d definitely recommend purchasing one of the hardwood options, such as Oak or Walnut, instead of Pine, as Pine probably doesn’t have the strength required for this build.
To cut your parts to length, I’d recommend using a miter saw or circular saw. Make sure to cut your parts nice and square and keep the parts the exact same length. Below are the dimensions for the pieces:
  • 4 pieces of 1x2 at 24 ½” long
  • 2 pieces at 1x2 18 ⅝” long
The leg pieces have a 45 degree miter cut on one end of the piece (see the picture).
Step 3: Layout Half Lap Joinery & Cut Using Method of Your Choice
Picture of Layout Half Lap Joinery & Cut Using Method of Your Choice
To join the two leg pieces in the X-shape, I used a joinery method called a “half lap”. Essentially, you remove an equal amount of material from each board and they fit together in the negative space. See the illustration below to better understand how half laps work.
You have a bunch of options for cutting half laps: a table saw, a miter saw with a depth stop, or a circular saw. Pick your favorite method and cut the half laps halfway up the leg, starting about 11 ½” from the bottom and ending about 13” from the bottom, if you’re using 1x2s. The half laps should be half the thickness of your material, so if you’re using a 1x2 with a thickness of ¾”, your half lap would be ⅜” deep.
Step 4: Layout Dado Joinery & Cut Using Method of Your Choice
Picture of Layout Dado Joinery & Cut Using Method of Your Choice
Next, you need to cut the dados for the stretchers that connect the legs. Again, I did this on my table saw but the same method you used for the half laps would work. The dado should be the same size as your stretcher. If you’re using 1x2s, it will be ¾” deep by 1 ½” wide. It makes life easier if you tape your legs together and cut all of the dados at once.
Step 5: Drill Holes for Dowel Bolts & Shape Legs
Picture of Drill Holes for Dowel Bolts & Shape Legs
With the legs still taped together, drill a hole through all of the legs centered at the top end of the legs. If using 1x2s, this measurement will be ¾” from the top and ¾” from the edge.
Next, cut two pieces from your 2” dowels to 18 ⅛” long using a miter saw, then trace the outline of the dowel onto the legs. Use a belt sander or file to remove material until the top end of the legs are rounded to match the dowels.
Step 6: Sand Parts & Assemble Stool Base
Picture of Sand Parts & Assemble Stool Base
Before assembling the base, I sanded all of the pieces with 120 grit sandpaper. For assembly, I applied glue to each part of the joints and clamped them together, wiping away any excess glue squeeze-out.
Step 7: Drill Holes for Threaded Inserts & Install Into Dowels
Picture of Drill Holes for Threaded Inserts & Install Into Dowels
The dowels are attached to the base using bolts through the legs that thread into threaded inserts in the ends of the dowels. To install the threaded inserts, drill a hole in the center of the dowel and then thread in one of the inserts. A little Super Glue will help keep the inserts in place.
Step 8: Measure for Leather Seat & Cut Leather to Size
Picture of Measure for Leather Seat & Cut Leather to Size
Now that the dowels are installed, you can measure the size of the piece of leather needed for the seat. Make sure to account for the length that will be glued together. My piece of leather ended up at 32” by 16 ½”.
I bought the leather from Tandy Leather, a popular leather supply store, and cut the piece to size using a utility knife and straight edge. I cut the corners round using the same utility knife, just to give it a cleaner look.
Step 9: Bevel & Slick Leather Edges
Picture of Bevel & Slick Leather Edges
To give the edges of the leather a more finished look, I used a edge beveler and wood slicker to round over the edges. These are common, inexpensive leather working tools that give you piece a more professional look. This step is optional but highly recommended.
Step 10: Glue Leather to Form Loops
Picture of Glue Leather to Form Loops
To glue the leather together to form the loops which will go around the dowels, I used barge cement, a glue that’s designed to work with leather. I applied the barge cement and followed the directions outlined on the package, allowing the barge cement to setup for 15 minutes before clamping the pieces together.
Step 11: Apply Neatsfoot Oil to Leather
Picture of Apply Neatsfoot Oil to Leather
To finish the leather, I applied a few coats of Neatsfoot Oil, a natural leather conditioner. I just wiped it on with my hands and let it dry overnight, reapplying a second coat on the second day. It goes on very dark but lightens significantly after 24 hours.
Step 12: Install Rivets in Leather Seat
Picture of Install Rivets in Leather Seat
I used a round drive punch to create the holes for the rivets, using a No. 4 punch which matched the size of the rivets I used.
The Arrow rivets I used were 3/16" (5mm) x 1/2" (12mm) Aluminum pop rivets, model # RLA3/16IP. I also used 3/16" (5mm) Aluminum pop rivet washers, model # WA3/16. To install the rivets, I used the Arrow Fastener RH200S Heavy Duty Rivet Tool.
Rivets are extremely simple to install with a rivet tool. Put the thin section of the rivet in the end of the rivet tool then put the thick portion of the rivet through the hole in the seat. Add a washer on the back side of the seat and then squeeze the rivet tool a few times until it clicks.
This click signifies that the rivet is set, and you’ll need to squeeze the tool one more time to remove the excess rivet material. It’s as simple as that!
Step 13: Apply Finish to Stool Base
Picture of Apply Finish to Stool Base
With the leather seat done, the last part of the build was applying finish to the wooden base. I applied three coats of a satin wipe-on polyurethane finish, sanding between coats with 400 grit sandpaper.
Step 14: Assemble Stool & Enjoy!
Picture of Assemble Stool & Enjoy!
Finally, assemble the stool by attaching 2” bolts through the outside of the legs into the threaded inserts in the dowels. Make sure to use washers beneath the bolt heads. Once the seat is installed, the stool is done!
Thanks for checking out this project! If you enjoyed it, make sure to check out my YouTube channel and my website for a lot more projects where that came from. Until next time, happy building!
TerryJo (author)2017-06-22
Very nice. I saw furniture similar to your stool at the UT El Paso library, but it was in the form of a chair with armrests and leather back. Nicely done.
EmmitS1 (author)2017-06-22
This type of stool has been modern for a long time. They found one very similar in Pharaoh Tutankhamen's tomb. It has to be a good design to last that long.
mreith (author)2017-06-22
Beautiful craftsmanship. As an old leather worker, I have to complement you on your work (I used to carve purses, belts, wallets and have made everything from squaw boots to moccasins). Barge cement was my go-to adhesive as it is so strong. You used some high-quality leather, the sort that is used for carving. But other options for those wishing to save money would be chrome tanned, pigskin, and other hides, as long as they go with the heavier weights to avoid stretching. Of course, your project would be a lot of fun to do with a carved and tooled design. My first vision when I saw the high quality of your work, was to want to do it with a nature scene carved into the leather, tooled, and dyed with bright colors, and then toned down with a nice antique finish. Another thought I had was using an ancient world map as the design for carving/tooling. A simpler way to dress it up would be to lace the edges with a quality leather lace. I better stop before I start spending money........
hjjusa (author)2017-06-20
excellent, I see a camp stool here. Add a back and it becomes a chair
craftedworkshop (author)hjjusa2017-06-21
Thanks, definitely would make a great camp stool!
diycreators (author)2017-06-21
You do great work J!
Thanks Glen!
Nuonaton (author)2017-06-20
love it!!!
craftedworkshop (author)Nuonaton2017-06-20
Thanks!
About This Instructable
5,584views
125favorites
License:
Bio: Weekly how-to project videos about #woodworking, metalworking, and more. #Maker. Created by Johnny Brooke.
More by craftedworkshop:DIY Floating Wall-Mounted Bike Rack (Free Template!)Walnut and Copper Cutting Board / Serving Board!5 Woodworking Tools for Beginners
Add instructable to:
