Modern Clock With Gear Look
Published
Introduction: Modern Clock With Gear Look
A nice design easy to build custom wall clock
Step 1:
by using the 12 teeth gear template in the first photo you can cut out the design on the bandsaw or by hand. then you drill a hole in the center and carve out the space in the back for rhe clock mechanism
Step 2:
i used a oak vineer 17mm mdf piecefor my gear and stained it and coated with clear satin varnish
Step 3:
this part is a bit tricky.i found aluminum numbers in my local hardware store fitting my clock perfectly and glued them on to make the digits of the clock.if you have a laser cutter it would be easy to get creative and create your own!
Step 4: Finish
assemble the clock mechanism add a hook to hang it on the wall and you're done!
    • Woodworking Contest
      Woodworking Contest
    • Casting Contest
      Casting Contest
    • Make it Move Contest
    2 Comments
    very cool work. thank you for sharing
    Good looking clock
