3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Modern style table from scrap plywood
I had a lot of leftover plywood and veneer and always thought ply has its own interesting symmetrical grain.
So with a lot of glue and clamping I finally got the result I wanted.
The general shape was cut out with the band saw.
I finished up with a disc sander.
Niall Mc Keown.
http://www.designagainstthegrain.com
Step 1Gluing the blocks
Gluing the blocks
20 comments
May 12, 2012. 10:33 AMwidget2007 says:
that is absolutely gorgeous, very creative idea, very skillful application!
Jan 28, 2012. 6:49 PMcaitlinsdad says:
That is a nice piece of furniture. Any insight into how you connected the legs to the table underside and how you mounted it to the wall? I would love to try dyeing or staining a few pieces before lamination and make my own zebrawood. Maybe do something with all that sawdust too.
Feb 16, 2012. 3:17 PMTimS124 says:
I've seen small pieces of colored plywood at various woodworking stores and was surprised to find it available in larger sizes just now while trying to verify the product's name. I found two versions, both from the same company, while searching for an answer just now:
http://www.rutply.com/products/dymondwood.html
http://www.rutply.com/products/colorwood.html
Dymondwood is available up to 2" thick and Colorwood is available up to 3" thick. That would simplify making something like this from those woods (though shipping costs vs. the free scraps you used is a hard battle to win). :-)
I have no association with the producers of those products…but now that I know I can get bigger sizes (and thicker pieces) I may become one of their customers.
Jan 31, 2012. 5:01 PMcaitlinsdad says:
My favorite woodworking tool is the Kreg pocket hole jig. It is great for making a set of pocket screw holes to attach a piece to studs in the wall. No need for an ugly cleat. You can also plug up the holes if they show on a visible side.
Feb 7, 2012. 8:48 AMblkhawk says:
Love the effect of all those pieces together to form the legs at the end. Great work!
Feb 2, 2012. 10:15 AMPACW says:
Layers! Such lovely lovely layers.
It's like the wooden cousin of perfect croissant dough!
Jan 29, 2012. 12:59 AMpfred2 says:
I think I have the same Makita sander. I found I didn't care for mine with PSA discs on it. Too much of a pain to peel them off. Now I use the same center hole discs I use on my angle grinders with it. That makes it more like them, but a lot tamer.
Just now I've come up with an idea to make a new sander pad for it out of jug LDPE. I'll have to see how that works.
Jan 31, 2012. 1:51 PMpfred2 says:
I was thinking I could even make a few discs so I could change grits and be able to reuse the PSA sanding discs a couple times. I got my sander used at a flea market so I didn't get the instruction book with it etc. But I really don't think it was made to run PSA discs. They just stick to that black plastic backer disc on my sander too good.
I've a lull in my present project while some glue sets up so I'm going to try it out right now.
It works for me. I attached a couple pictures that illustrate the process I used to make the disc. I did the final truing running it against my disc sander. Check the white skid mark I left in the picture. That came right off with some steel wool.
Anyhow it depends on if the screw sticking through the middle is a show stopper for you whether this will work for you or not. That doesn't bother me. I still haven't sanded so much I heated up the disc a lot, then tried to peel it, but I sanded some, then peeled and it seemed OK.
It is still early but so far I'd have to call this a success.
Jan 28, 2012. 7:05 PMjessyratfink says:
This is beautiful. :) I'd love to find out more about the little details.
Jan 28, 2012. 9:01 PMPenolopy Bulnick says:
That is quite beautiful! How long did it take to make?
Jan 30, 2012. 11:25 PMbertus52x11 says:
Very nice, but how did you clamp the blocks together while glueing? (without them sliding apart).
Jan 30, 2012. 2:29 PMkenbob says:
Wow! Love the table, love the concept, love the execution.
Jan 29, 2012. 11:35 AMRaisedByRobots says:
exquisite!
Jan 28, 2012. 8:31 PMl8nite says:
that really is a gorgeous looking piece of wood
Jan 29, 2012. 12:17 AMpfred2 says:
It looks like many pieces to me.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
4
Author:niall mc(http://www.designagainstthegra)
