Modification to the Previous LCD Project
1,481
22
Posted in TechnologyArduino
Introduction: Modification to the Previous LCD Project
After publishing the previous post, my friend told me there is an easier way with a 10k potentiometer, so I use the potentiometer included in the kit and follow his diagram and did the wiring.......
Step 1: Wiring With Potentiometer
It works! Now I can turn the potentiometer to control the LCD!
I have also modify the code in Library a little bit. Here is the code:
// include the library code:
#include
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
void setup() {
// set up the LCD's number of columns and rows:
lcd.begin(16, 2);
// Print a message to the LCD.
lcd.setCursor(0,0);
lcd.print("Hey, pretty lady");
lcd.setCursor(0,1);
lcd.print("Go to see movie");
void loop() {
// Turn off the display:
lcd.noDisplay();
delay(500);
// Turn on the display:
lcd.display();
delay(500);
Step 2: Try to Make It Moves
But the text is just limited to 16x2, which is definitely not enough for my "paragraph". : ) So I modify the code again referring to http://arduino.cc/en/Tutorial/LiquidCrystalScroll
#include
void setup() {
lcd.begin(16, 2);
lcd.setCursor(0,0);
lcd.setCursor(0,1);
void loop() {
// scroll 13 positions (string length) to the left
// to move it offscreen left:
for (int positionCounter = 0; positionCounter < 13; positionCounter++) {
// scroll one position left:
lcd.scrollDisplayLeft();
// wait a bit:
delay(150);
// scroll 29 positions (string length + display length) to the right
// to move it offscreen right:
for (int positionCounter = 0; positionCounter < 29; positionCounter++) {
// scroll one position right:
lcd.scrollDisplayRight();
// wait a bit:
delay(150);
// scroll 16 positions (display length + string length) to the left
// to move it back to center:
for (int positionCounter = 0; positionCounter < 16; positionCounter++) {
// wait a bit:
delay(150);
// delay at the end of the full loop:
delay(1000);
It can move the whole text to left and right now.
Step 3: Make a Little Change Further
Then I extent the text to a sentence and delete part of the code to let it moves to the left only. The final code is as follow:
#include
void setup() {
lcd.begin(16, 2);
lcd.setCursor(0,0);
lcd.print("Hey, pretty lady, let's go to see a");
lcd.setCursor(0,1);
lcd.print("movie and have a dinner tonite");
void loop() {
// wait a bit:
delay(150);
Finished! Next time I will start a new project with different stuffs. See you.
    • Microcontroller Contest
    • Woodworking Contest
      Woodworking Contest
    • Casting Contest
      Casting Contest
    3 Comments
    ok heere some thing really screwed up with instructables. it allows me to log in. but i cant make a simgle post wat so ever on the page i logged in under. but , even if i go back to that page it wont let me wat so ever. now it fine with me poating any where else but , there.
