3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Modified IKEA GALANT desk
Step 4Underside of pegboards
Here's some shots of the underside of the pegboards. Medium and long zip cords are all I used to attach anything from a coil of extra cable to heavy external harddrives. They come in packs of 15-20 at hardware and home improvement stores.
I daisy-chained two power bars. Each white power bar is connected to a black power bar, which in turn is plugged into a separate wall plug-in as to not blow a fuse.
6 comments
Apr 24, 2011. 9:24 AMfresnelman90 says:
I really like this, for it keeps your workspace nice and clean. I will definitely do this with my future desk!
Jan 4, 2010. 9:49 AMveeguy says:
You are aware that you can buy zip ties with screw holes on the end, right?  That would have obviated the need to buy and mount pegboard under the desk top in the first place.
Feb 23, 2010. 11:45 PMLance Mt. says:
I like the unquie ablility of this to add jsut about anything you want to it. It works, its simple and best of all its quick.
Sep 17, 2009. 7:54 PMericharper says:
I hate to burst your bubble :) but all of your electrical receptacles are likely to be on the same circuit, so if the current load for everything is too much, you're going to blow a fuse (or trip a breaker) anyway. Fortunately, computer and mid range stereo equipment isn't going to draw much current anyway.
Mar 31, 2008. 1:12 AMsplendidus says:
I really like the idea of using peg board to control wires and mount equipment. I was just wondering, how do you add wires, etc.? It seems as though it would be very tough to add new zip-ties once the desk top is in place. Do you have a good method for getting around this?
Apr 1, 2008. 6:47 PMvendebted says:
Grab a pair of pliers and put a number of creases in the end of the cable tie. Make two 90 degree angles in it, so that it looks like there is a small box on the end of it. Then you should be able to put the cable tie through on whole and with a little bit of maneuvering you should be able to get it through the other target whole. I work in a hardware store and zip tie stuff to the pegboard all the time. And this sure seems to do the trick for me. Great Idea with the peg board by the way.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
5
Author:kahunna
