loading
Step 1: Components & Wiring
I have tested this guide with the following:
PARTS
WIRING
  • HC-05 GND --- Arduino GND Pin
  • HC-05 VCC (5V) --- Arduino 5V
  • HC-05 TX --- Arduino Pin 10 (soft RX)
  • HC-05 RX --- Arduino Pin11 (soft TX)
  • HC-05 Key (PIN 34) --- Arduino Pin 9
<p>this is what i get in serial monitor on an UNO </p><p>cant seem t get any AT response from any app or program. also tried ftdi unit.</p><p>it connect via BT but does accept any commands from terminal.. tried a few different sketches and techniques..</p><p>THNX</p>
<p>I had the same problem. You have to set 'Newline' to 'Both NL &amp; CR', if that doesn't solves your problem try to set '38400 baud' to '9600 baud' (That worked for me)...</p>
<p><br>I made all thatand still not working</p>
<p>I have the same problem .. What didi you do so that it works ?</p>
<p>thank you! worked for me so far Im getting responses atleast, havent tried an actual bluetooth connection yet but thanks for your article.</p><p>just a note... I have the HC-05 with the EN Key &amp; the method DrMike suggested worked for mine module</p>
<p>One more pitfall - my board had an EN pin in place of KEY. This is different (- and means you can disable the board to save current when not in use). Instead there a button. Pressing this pulls the KEY input to the internal 3v3 line. I found that it could be released after a few seconds and I could rename and change baud rate. Mike</p>
<p>Didn't work at first. I then realised (after using a ftdi cable and Realterm) that I needed to have 'Both NL &amp; CR' selected in the serial monitor for sending the serial data. Hope this helps others avoid this pitfall. Mike</p>
<p>I guess it is different for every module. My HC-05 was on 9600 in both modes.</p><p>My sequence was fairly simple. I used an ftdi module</p><p>Connect the necessary pins:</p><p>tx-rx<br>rx-tx<br>vcc-vcc<br>gnd-gnd<br>state-Vcc</p><p>plug ftdi module in usb,</p><p>open serial monitor, set to 9600 baud</p><p>Press the little 'state' button on the module some 4-5 sec</p><p>enter AT in the serial monitor. if it comes back with 'OK' you are good to go</p>
<p>It works also with Arduino Nano. It is important to remember that HC-05 modules tagged ZS-040 work with power between 3.6 and 6 V and RX and TX at 5V. When I tried to drive RX at 3.3 V , I had no response. Finally, RX and TX work at 9600 b/s , and at 38400 in AT mode.</p>
I connected hc05 module with arduino uno board with connections as- <br>G<br>HC-05 GND --- Arduino GND Pin<br>HC-05 VCC (5V) --- Arduino 5V<br>HC-05 TX --- Arduino Pin 10 (soft RX)<br>HC-05 RX --- Arduino Pin11 (soft TX)<br>HC-05 Key (PIN 34) --- Arduino Pin 9<br>After connecting i m getting rapid blinking of led on hc 05 module but unable to connect with any app on ios neither AT command is getting any response on serial port.<br>Suggest how to connect hc05 with arduino uno and how to use it on ios mobile app
<p>If it has a small button above the EN/KEY/WAKE UP pin, disconnected Vcc, press and hold that button, connect Vcc and it the LED in the module should blink slowly and allow you to enter AT codes.</p><p>Regards,</p>
<p>This worked for me too. Also, after getting the LED to blink slowly, press the Reset button on the Arduino. Exact steps that seem to always work: </p><p>1. Unplug power from HC-05</p><p>2. Upload sketch from this Instructable</p><p>3. Hold in HC-05 button</p><p>4. Reconnect power to HC-05 (wait until LED blinks slowly)</p><p>5. Press Arduino reset button</p><p>6. Open Serial Monitor</p><p>7. Make sure &quot;Both NL &amp; CR&quot; is selected</p><p>8. Type AT commands</p><p>We had 3 people in a workshop this evening and when everyone followed this procedure it always worked. </p>
<p>NOT REPLAY FROM SERIAL MONITOR</p>
<p>i followed your procedure but still i get weird output in for of some other language. but when i put the baud rate to 9600 it shows english and then an error message comes up......plz help</p>
<p>I had steps 3 &amp; 4 reversed above -- my apologies. They should be: </p><p>3. Reconnect power to HC-05</p><p>4. Hold in HC-05 button (wait until<br>LED blinks slowly)</p><p>(9600 baud is correct for the serial monitor)</p>
<p>that worked perfectly</p><p>thanks</p>
<p>pin 34 cannot be connected directly to Arduino PIN 9, use level converter from 5 volts to 3.3 and vice versa or simply use two 1 K ohm resistors between PIN 9 and VSS and connect pin 34 inbetween </p>
<p>i have done whole connection and program but still not work serial comm. is not done and led of HC 05 is blink continuously. </p>
<p>Just what I was looking for, thank you very much.</p>
<p>It work</p><p>Thank you</p>
<p>Great tutorial,</p><p>Thank for the help,</p><p>Roland</p>
<p>I can transmit data from PIC controller -&gt;hc-05-&gt; mobile terminal but can't receive back data into PIC controller from mobile terminal.</p><p>Can any body help me with solution?</p>
<p>hey dudes</p><p>I've got a cz hc 05 bluetooth module</p><p>when i connected this to my arduino mega 2560, it worked fine, with the LED's blinking indicating it was working. I even managed to pair it with my android device. However, soon after i paired it, the module stopped blinking and i cant seem to get it working again..</p><p>Does anybody know what the problem is? Or did is the module broken?</p>
<p>I know have 5 hc-05s here at home and trying to connect to them each with the same generic name was terrible. I have been trying to get my hc-05s into command mode and successfully connect to them for weeks -- as an off and on project. Finally, with this instructable and an Arduino Nano I got it all to work because of connecting to D10, D11 instead of the Tx and Rx on the Nano. Thanks for writing this great instructable. Also, since my hc-05s all have the button, I can just hold that while powering them on and the device enters into AT mode. No need for the additional wire on pin 9 or the associated code.</p>
<p>Hi, instead of your pinout I have:</p><p>state, rxd, txd, gnd, vcc, en</p><p>Is the &quot;en&quot; pin seme as &quot;key&quot; pin? The &quot;state&quot; and &quot;en&quot; pins haven't got pins to connect to breadboard (there are only 4 pins, but other 2 are marked amd seem like they're ready to be soldered to pins, they have holes).<br>Sorry for my english and thanks for answer!</p>
<p>u got output using that bluetooth module ?</p>
<p>when connected tx-rx,rx-tx,gnd-gnd,vcc-5v, starts blinking. when trying to connect, ligts without blinking. But phone says something like couldn&acute;t connect and bluetooth starts blinking again.</p>
<p>Like on this picture: <a href="http://www.martyncurrey.com/wp-content/uploads/2014/10/HC-06_zs-040_01_1200.jpg" rel="nofollow">http://www.martyncurrey.com/wp-content/uploads/2014/10/HC-06_zs-040_01_1200.jpg</a></p>
<p>Hi, I'm working with the arduino Due and SoftwareSerial doesn't work. I'm not that great with the coding, so could you help me out?</p>
<p>Instead of getting an OK after typing AT in the serial monitor, I am getting the following output. Please someone tell me the reason</p>
<p>that my be due to mismatch of buad rate </p>
<p>//Correction :</p><p>#include&lt;SoftwareSerial.h&gt;</p><p>SoftwareSerial BTSerial(10,11);</p><p>String HC05_Responce=&quot;&quot;;</p><p>void setup(){</p><p> pinMode(9,OUTPUT);</p><p> digitalWrite(9,HIGH);</p><p> Serial.begin(9600);</p><p> Serial.println(&quot;Enter AT command:&quot;);</p><p> BTSerial.begin(38400);</p><p>}</p><p>void loop(){</p><p> if(BTSerial.available())</p><p> Serial.write(BTSerial.read());</p><p> if(Serial.available())</p><p> BTSerial.write(Serial.read());</p><p>}</p>
<p>HELLO KJOHARI21</p><p>Instead of no line ending drop the menu down and select &quot;Both NL &amp; CR&quot;</p><p>and try again.</p><p>cheers ;)</p>
<p>HiKjohari21, il think you have to select &quot;both line feed and carriage return&quot; in the serial monitor and it will work.</p><p>Regards.</p>
<p>If there is anyone still struggling out there, I made another instructable detailing how to use this modules in master, and slave mode. It is meant to explain how to get each model into AT mode, and then, to get them working with code.</p><p>https://www.instructables.com/id/Arduino-Bluetooth-Master-and-Slave-Using-Any-HC-05/</p>
<p>Hello to everyone.I have make a bleutooth robot which i can control it via android(tablet) and i have a problem with the code.I want from the robot to stop when connection lost or bluetooth disconnected.Now when the connection lost the robot go ahead and falls on the objects.How to add this line on the code?Can you help me please?The STATE pin of HC-05 when is HIGH is connected and when is LOW is disconnected.I put this on my code but it doesn't stop.Thank you for your time</p><p><br>The bluetooth that i use is HC-05<br><br>My code:<br><br>#include &lt;Servo.h&gt;<br><br>Servo SERVO_1; // Initialize Servo1<br><br>// Motor Control Variables<br>int PWM1 = 9;<br>int ENABLE1 = 8;<br>int PWM2 = 5;<br>int ENABLE2 = 7;<br>int PWM3 = 3;<br>int ENABLE3 = 4;<br>int PWM4 = 6;<br>int ENABLE4 = 12;<br>int STATE=2;<br><br><br>void setup() {<br> SERVO_1.attach(10);<br> Serial.begin(9600);<br> pinMode(ENABLE1, OUTPUT); //&Delta;ή&lambda;&omega;&sigma;&eta; ό&lambda;&omega;&nu; &tau;&omega;&nu; &mu;&epsilon;&tau;&alpha;&beta;&lambda;&eta;&tau;ώ&nu; &omega;&sigmaf; έ&xi;&omicron;&delta;&omicron;&sigmaf;<br> pinMode(ENABLE2, OUTPUT); //&Delta;ή&lambda;&omega;&sigma;&eta; ό&lambda;&omega;&nu; &tau;&omega;&nu; &mu;&epsilon;&tau;&alpha;&beta;&lambda;&eta;&tau;ώ&nu; &omega;&sigmaf; έ&xi;&omicron;&delta;&omicron;&sigmaf;<br> pinMode(ENABLE3, OUTPUT); //&Delta;ή&lambda;&omega;&sigma;&eta; ό&lambda;&omega;&nu; &tau;&omega;&nu; &mu;&epsilon;&tau;&alpha;&beta;&lambda;&eta;&tau;ώ&nu; &omega;&sigmaf; έ&xi;&omicron;&delta;&omicron;&sigmaf;<br> pinMode(ENABLE4, OUTPUT); //&Delta;ή&lambda;&omega;&sigma;&eta; ό&lambda;&omega;&nu; &tau;&omega;&nu; &mu;&epsilon;&tau;&alpha;&beta;&lambda;&eta;&tau;ώ&nu; &omega;&sigmaf; έ&xi;&omicron;&delta;&omicron;&sigmaf;<br> pinMode(STATE, INPUT);<br>}<br><br>void loop() {<br><br> if(digitalRead(STATE)== HIGH)<br><br> // see if there's incoming serial data:<br> if (Serial.available() &gt; 0) {<br> // read the oldest byte in the serial buffer:<br> int incomingByte = Serial.read();<br> // action depending on the instruction<br> // as well as sending a confirmation back to the app<br> switch (incomingByte) {<br> case 'F':<br> moveForward();<br> Serial.println(&quot;Going forward&quot;);<br> break;<br> case 'L' : // Case 'L' is received,<br> SERVO_1.write (180); // &Sigma;&tau;&rho;ί&psi;&epsilon; &Alpha;&rho;&iota;&sigma;&tau;&epsilon;&rho;ά.<br> SERVO_1.attach(10);<br> break;<br> case 'N':<br> turnright();<br> Serial.println(&quot;Turning right&quot;);<br> break;<br> case 'M':<br> turnleft();<br> Serial.println(&quot;Turning left&quot;);<br> break;<br> case 'O' : // Case 'L' is received,<br> SERVO_1.write (0); // &Sigma;&tau;&rho;ί&psi;&epsilon; &Alpha;&rho;&iota;&sigma;&tau;&epsilon;&rho;ά.<br> SERVO_1.attach(10);<br> break;<br> case 'B':<br> moveBackward();<br> Serial.println(&quot;Going forward&quot;);<br> break;<br> case 'P':<br> SERVO_1.write(90); // &Sigma;&tau;&rho;ί&psi;&epsilon; &Alpha;&rho;&iota;&sigma;&tau;&epsilon;&rho;ά.<br> SERVO_1.attach(10);<br> break;<br> case 'S':<br> moveNone();<br> Serial.println(&quot;Stopping&quot;);<br> break;<br> default:<br> // if nothing matches, do nothing<br> break;<br> }<br> }<br>}<br><br>void moveForward() {<br> // turn the driving motor on to go forwards at set speed<br> digitalWrite(ENABLE1, HIGH);<br> digitalWrite(ENABLE2, HIGH);<br> digitalWrite(ENABLE3, HIGH);<br> digitalWrite(ENABLE4, HIGH);<br> analogWrite(PWM1, 255);<br> analogWrite(PWM2, 255);<br> analogWrite(PWM3, 255);<br> analogWrite(PWM4, 255);<br><br>}<br><br>void moveBackward() {<br> // turn the driving motor on to go backwards at set speed<br> digitalWrite(ENABLE1, LOW);<br> digitalWrite(ENABLE2, LOW);<br> digitalWrite(ENABLE3, LOW);<br> digitalWrite(ENABLE4, LOW);<br> analogWrite(PWM1, 255);<br> analogWrite(PWM2, 255);<br> analogWrite(PWM3, 255);<br> analogWrite(PWM4, 255);<br>}<br>void turnright() {<br> digitalWrite(ENABLE1, HIGH);<br> digitalWrite(ENABLE2, HIGH);<br> digitalWrite(ENABLE3, LOW);<br> digitalWrite(ENABLE4, LOW);<br> analogWrite(PWM1, 255);<br> analogWrite(PWM2, 255);<br> analogWrite(PWM3, 255);<br> analogWrite(PWM4, 255);<br>}<br><br>void turnleft() {<br> digitalWrite(ENABLE1, LOW);<br> digitalWrite(ENABLE2, LOW);<br> digitalWrite(ENABLE3, HIGH);<br> digitalWrite(ENABLE4, HIGH);<br> analogWrite(PWM1, 255);<br> analogWrite(PWM2, 255);<br> analogWrite(PWM3, 255);<br> analogWrite(PWM4, 255);<br>}<br>void moveNone() {<br> // turn the driving motor off<br> digitalWrite(ENABLE1, 0);<br> digitalWrite(ENABLE2, 0);<br> digitalWrite(ENABLE3, 0);<br> digitalWrite(ENABLE4, 0);<br> analogWrite(PWM1, 0);<br> analogWrite(PWM2, 0);<br> analogWrite(PWM3, 0);<br> analogWrite(PWM4, 0);<br> SERVO_1.detach();<br>}</p>
<p>Thanks a lot!</p>
<p>I'm encountering a problem :</p><p>I've plug my HC-05 through arduino uno, on the serial monitor it say &quot;ready for AT commands&quot;.</p><p>Then i wrote &quot;AT&quot; in the monitor but no OK answer </p><p>What Should I do ?? </p><p>Thanks</p>
<p>IM HAVING THE SAME PROBLEM</p>
<p>i want to connect HC 05 with RX65N (100 pin). i made pin 34 high HC 05 entering in command mode but it is not responding back</p><p>which register has to be connected between vcc and pin34</p>
<p>My HC-05 is already blinking slowly (every 2s), but when I send 'AT' from serial monitor, I get nothing. I use the same code in this instructable. Someone, please help me.</p>
<p>An enjoyable come across by chance on Youtube so later on in the day I worked through most of the instructable.</p>
What should I do if I receive some unreadable character<br>Plzz reply
<p>hi I just have to get data from the pin 7 of Arduino do I need to configure the hc05 ?</p><p>plzz help me the coding too </p>
<p>do i have to change the default AT setting on bluetooth to make it work with my android</p>
<p>hi there </p><p>can we connect more than 4 hc-05 in slave and one hc-05 module in master </p>
<p>Hi, thank you for this instractable...</p><p>I am very glad to explore HC05 Bluetooth.</p><p>my HC05 module doesn't have a connection to the KEY pin instead I have an ENABLE pin and a small tactile switch that is not connected to any pin.</p><p>so; I took a wire from pin 34 and put it in-between two serially connected 1 K Ohm resistors between PIN 9 &quot; Arduino&quot; and VSS. </p><p>put 3 new lines in the Arduino sketch and my sketch is as follow:</p><p>///////////////</p><p>#include &quot;SoftwareSerial.h&quot;</p><p>SoftwareSerial BTSerial(10, 11);</p><p>void setup() {<br> pinMode(8, OUTPUT); digitalWrite(8, LOW); </p><p>// connected to the VCC of the Bluetooth module</p><p><br> pinMode(9, OUTPUT); digitalWrite(9, HIGH); </p><p><br> Serial.begin(9600);<br> <br> delay(1000);<br> <br> Serial.println(&quot;Enter AT command mode&quot;);</p><p> digitalWrite(8, HIGH);<br> BTSerial.begin(38400);</p><p>}</p><p>void loop() {<br> if (BTSerial.available()) Serial.write(BTSerial.read());<br> if (Serial.available()) BTSerial.write(Serial.read());</p><p>}</p><p> /////////////////</p><p>I have one idea for this instractable; that is not to play with the wire manually; instead let Arduino do the connection for you...</p><p>and this work very well every time i upload a new sketch </p>
<p>can anyone please tell me how can i change data rate in Hc-05?</p><p>and how to change the class of device? what will happen if i change the class? whether it would affect the data rate or something?</p>
<p>AT+CLASS=&lt;Param&gt;</p>
<p>can u please tell me how to change my pin or password for my hc-05??</p>
About This Instructable
607,586views
393favorites
License:
Bio: Did I unplug the solder iron?
More by techbitar:IR Remote Control Station for Android - TURN THE TV DOWN SensoDuino: Turn Your Android Phone into a Wireless Sensors Hub for Arduino Modify The HC-05 Bluetooth Module Defaults Using AT Commands
Add instructable to:
