Step 6New Components pt.2
1. To perform the Seeing Eye mod, you have to connect a 3mm red LED to D5 as shown. We will later mount this in the 'o' of tone.
2. For the Ultra mod you switch in another LED in series with D4 as shown. This LED will be on the inside and wont be seen.
Follow the diagram.
This is where you will most likely make a mistake if you are not careful. DOUBLE CHECK EVERYTHING!! If you wire it all up and the LED appears dim and you just put a new battery in it, You most likely put an LED or the orange diode in the wrong way. Make sure to leave enough wire to mount the LED and switch.
For the Ultra Mod you need to desolder D4 and solder a jumper to the switch as shown. Don't forget the orientation of the Diode.
Once all of you wires leading out of A,B,C, and D on the diagram are are soldered to the board, solder 1.0 uF capacitor into C9.
Last thing is to solder the 47pf cap across the back of D5 and D4 as shown.
6
comments
Add Comment
mwilhoit
says:
James Haskin (author)
says:
says:
says:
Add Comment
