3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Modify Your Wah Pedal
After making my talk box I started surfing the web for other guitar related things I could do myself. I found loads of info on the Dunlop GCB-95 wah pedal. This Instructable will walk you through all of the modifications I made to my wah pedal...
*True Bypass Mod
*Volume Boost Mod
*Wah-Volume Pedal Mod
*Vocal Mod
*Midrange Mod
After having completed all of these mod and a few others I recommend doing them one at a time and testing in between mods so if you don't like something, you can easily reverse it.
Your gonna need some basic soldering tools...
-good soldering iron (mines a Weller WESD51D I got for christmas)
-solder
-wire cutter/stripper
-helping hand (a must!!)
also the to wire anything to the board itself you will need 24AWG wire
Step 1Research
Research
I think this is a big step in all of my projects. You don't want to just jump in without input from multiple sources. A few of the site that helped me were...
http://homepage.ntlworld.com/s.castledine/greenfuz/wah.html
http://www.stinkfoot.se/andreas/diy/mods/dunlop.htm
http://www.guitarzone.com/forum/index.php?showtopic=176864
http://www.geofex.com/- click "FX Technology
-Technology of the..." in the upper left
http://www.geocities.com/overdrivespider/tb.htm
http://www.geocities.com/j4_student/schematics.htm
These are some pictures I found useful...
43 comments
1-40 of 43next »
Sep 8, 2011. 12:40 PMArtXander says:
Hi! I haven't understand how to wire the pot. I must connect the pot where there is the 33k resitor? 1&2 lug together to a side and 3 to the other?
Jul 26, 2011. 8:41 PMangelofdeth68 says:
Great instructable. thanks.
Apr 30, 2011. 12:30 PMjphoton says:
hi guys, lifting the ground of the cap in question will indeed kill MOST of the wah effect, but it will not make it a true volume pedal...it will make it a tone pedal for all intents and purposes. it will kinda work on volume...sort of...but it won't be a true volume pedal. tried it on my old gcb95 long ago, was too lazy to un-do it...it can be interesting, but don't be disappointed when it doesn't work the way you'll probably envision. good luck mate!
Jan 13, 2011. 1:37 PMJezrael says:
Wich resistor do you recommend to replace the 68k resistor? or, wich value did you use? Greetings
Sep 2, 2010. 4:42 PMthewizard42 says:
Do you mean spdt? or does it have to be double pole, because i do not see why you would need the second pole
Jun 10, 2010. 3:38 PMoverdrive555 says:
hi boys, why u dont use a trimmer to replace 1.5resistor?
Jun 3, 2008. 12:41 PMbutthead95 says:
Buy the Crybaby From Hell it has most of this stuff inclyuding a five selection knob for dif ranges
May 23, 2010. 7:57 PMDrXavierAJones says:
Yeah, its also 200 dollars.
May 22, 2010. 10:01 AMalenchence says:
Hi!
I have a problem:when I click on the link for the installation of a new switch,it says the instruction is no longer available,so please help me out!I would like to do this mod,tone sucking is driving me crazy!
Tnx
Mar 5, 2010. 3:07 PMmesaiphoneguy says:
 will this also work on a 535Q crybaby wah pedal?
Nov 28, 2009. 11:20 AMstupidityisagift says:
hey, can you mod it for volume another way besides the capacitor? i have a snarling dog wah and want to mod it for voume, and i doubt the capacitor switch will work the same
Aug 22, 2009. 7:02 AMrcrane says:
Hey, I am stuck. I have a green board like the one above and it is labeled 'E". I did the following: Removed old switch Removed the buffer components replaced the 33k with a 68k replaced the 1k5 with a 2.8k installed a 3PDT switch My problem is that I only have four wires to attach to the switch: 2 blue 1green 1purple I dont see any pictures showing the installation of the 3PDT usingmy board. Do I need to install wires where I removed the buffer and solder that to the switch? I don't know how to configure the wires on the switch. Help!
Aug 30, 2009. 7:31 AMrcrane says:
Got it! Sounds much better. Thanks for your help. I am still experimenting with the pot range. But MUCH more vocal and quiet! thanks again
Aug 23, 2009. 7:10 AMrcrane says:
James, Thanks for the quick response! So that explains how to wire the existing wires. I only changed two resistors and changed the switch, so I will attach the wires like you said and then I just need to add two wires to the area that I removed the buffer and wire them to 3? rcrane
Aug 26, 2009. 9:18 AMabehughesmusic says:
Hey I just did the Wah/Wolume mod, (that's the only mod I did). Admitably I didn't do a great soldering on the board, but all the contacts seem to be solid and the pedal basically does as it's supposed to. The problem I'm having is that in the Volume setting in the pedal doesn't get all the way quiet in the far back position. Did I miss something? This was my first attempt to mod a pedal and except for that one thing, which I'm really not going to loose sleep over, it seems to be working and not giving me any particular trouble. Thanks for this instructable. After I do some more work, I'm going to try a keely mod I found for my tube screamer, and (fingers crossed), try doing the seeing eye/ ultra mod for my DS-1. Thanks again.
Dec 10, 2008. 2:34 PMsomerockenguy says:
could you elaborate on this i would love to do this mod (wah-volume mod) but i only partly get how to do it. you think you could do an instructable on just that or point me to a web site that has a how to on it?
Jul 24, 2009. 9:33 PMmrwonkaland says:
hi. i dont know much about fixin these electronics but i can learn pretty fast. i was wondering if you could help me with my dimebag wah pedal. its not crying anymore. and that makes me sad. i thought it was the pot. but on ur blog u say its the capacitor. id rather take ur word over my assumption. id really appreciate it if you could help me out. u say to leave a #. i dont know if you were talkin to someone else or just offering yourself. but in any case, my number is 602.295.0008. my email is mrwonkaland@gmail.com thx for your time.
Jul 12, 2009. 9:44 AMstupidityisagift says:
hey, im a lil confused. is this mod for switching from the wah, to the volume mod, or is it wah volume combonation? thx
Jul 18, 2009. 6:31 AMoweng4000 says:
I had an idea for a mod that i hope will work. a switch on the side in order to switch inductorPr
Jun 4, 2009. 6:15 AMtrgz says:
I've got an old Cry Baby that, way back in the 80's, I modded it to be a Wah/Volume and I only used a couple of parts in the mod, sadly though I can't remember what they were but I suspect I managed it with a simple change to the stomp switch and/or pot (multi-way versions),- it might have shorted out/bypassed a section of the circuitry like above (James H). It's up in the loft but I un-modded it when I went thought about selling it (20 years or so ago).
Apr 25, 2009. 9:53 AMmabu4237 says:
Where does the switch for volume wah switching go?
Apr 13, 2009. 1:21 PMspiceyweasel says:
Sick! I've got a vintage Morley Distortion/ Wah pedal that also can be used for volume control. It'd be cool to add a few ring-dings to it. Thanks.
Apr 11, 2009. 1:25 PMpsychodeathmonkey says:
Hey anyone know what i need to make my wah into a wah/ring modulator like the snarling dogs mold spore or the arctec wish wah? I like the pedal ive got and dont really feel the need to buy another pedal. so anyone know what id need to do it. I pretty much know the basics , pots ,wires, and some kind of resisters, capaciters and all that stuff so. anyone help me out?
Dec 2, 2008. 2:02 PMReoTheYokel says:
You can prevent "sucking" the tone by using one of those True Bypass pedals. Or something like that. Justin Sandercoe reviewed it in one of his videos on Youtube. But, yeah, this is cheaper.
Nov 23, 2008. 7:07 PMmondaymonkey says:
I splurged and got myself a Dunlop 535Q. Love it to bits, but need a light to tell me if its on or off. I'm probably just going to have another push switch connected to a small battery and LED mounted on the underside of the foot control pedal
Oct 23, 2008. 9:58 AMavibank911 says:
dono if this is the right place to ask but- how do i add a string of led's to my volume pedal to indicate the postion of the potentiometer
Jul 12, 2008. 6:11 PMno food please says:
I'm looking into doing this, but I have the dime cry baby custom (model db-02). It contains mostly smd components and all of the circuit board traces are covered up and really hard to see. I can't find any pictures of other people working on it, or any circuit diagrams for it. There are some spots that don't have have anything soldered to them, but have traces leading up to them and labels (e.g. "C3" or "TP1").
Jul 14, 2008. 10:49 PMno food please says:
That is the correct pedal. I suspect the DB-02 and the DB-01(which has a switch and a potentiometer on the side of the pedal) use the same circuit board(or a very similar one). Here are some pictures of the DB-02:
http://www.flickr.com/photos/28577578@N05/2669716865/in/photostream/
Jun 12, 2008. 5:39 AMKoenB says:
Great mods! I never knew the sound would change so much by just changing caps.
All you need is my foot-on-pedal mod ;) check it out http://www.instructables.com/id/Foot-on-pedal-True-Bypass-crybaby-wah-mod/
1-40 of 43next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
66
Author:James Haskin
insasquatchcountry@yahoo.com
