Modify a Mini-B USB Cable to Power an Enclosed GoPro Hero3 (With Skeleton Back Door)
 by zplus
Featured
I got my GoPro Hero3 for Christmas, it is a fantastic camera.  However, the battery life leaves something to be desired.  Sure, you can buy a bunch of spare batteries and change them out periodically, but if you are taking a time lapse - you really do not want to move the camera.
Enter: The Frame
This is GoPro's answer to this problem.  Now you can shoot while being connected to an external power source.  But, wait, $40 for a piece of flimsy plastic (to be fair, TWO pieces of plastic!) with a few holes in the side?  No Thanks.
I really wanted this capability, but didn't want to spend a lot of money or sacrifice the poly case by drilling a hole in the side.
Enter: Modify a Mini-B USB Cable to Power an Enclosed GoPro Hero3 (With Skeleton Back Door) (This Instructable)
Disclaimer:  Perform this at your own risk, I take no responsibility for your actions and assume you have some competency. With that being said, this instructable is merely a cable modification, I do not modify the camera or case.
Step 1: Parts/Tools
You will need:
Parts-
-A Mini-B USB cable of your desired length.  I found an old 3-footer in my spare cables tub.  I might suggest not using the one included with your GoPro (just in case...).  Note: I have a Hero3 Black Edition which uses a Mini-B. I do not know what the Hero2 (or whatever) uses.  Also, of course, your cable design may be slightly different.
-Glue...?  I used some, it may not be needed though...
Tools-
-Wire Strippers/Cutters.  Not that you will be stripping wires explicitly - but you will need to cut off the black plastic molding around the connector and trim back the cable sheath.
-Long Nose Pliers.  For general dismantlement and metal bendage.
-Small Rotary Cutting Tool.  I use a really cheap one from Harbor Freight.  Yes, it is cheaply made and doesn't have a lot of power, but hey its like $10 on sale.
yamil008 says: Apr 23, 2013. 7:54 PM
Awesome! I think that you can use Sugru to cover the exposed wires and make it look nicer. Anyways, awesome instructable. I doing this one definitely
zplus (author) in reply to yamil008Apr 25, 2013. 6:05 AM
Maybe so but it is definitely a tight fit without modding the case! In fact, I was not worried about strain relief because the case kind of crimps down on those wires.
vkelman says: Apr 10, 2013. 6:13 AM
What type of external power source do you use? How long it allows camera to operate? I'd like to use Hero3 in the mountains...
zplus (author) in reply to vkelmanApr 25, 2013. 6:02 AM
I have only used this with a wall outlet with USB adapter. But yes I have seen those battery packs and would like to pick one up for long bike rides. A go pro battery is like 1000 mAh. But I have seen some of the packs rated around 10,000 mAh. That means you could potentially get 10x the battery life.
Vincent VD says: Apr 15, 2013. 6:58 AM
Great success! thnx for this tutorial! i'm still looking for a way to have both livestream to my computer and charging at the same time. using the 10.5.5.9:8080 way seems to be the only way...
zplus (author) in reply to Vincent VDApr 25, 2013. 5:54 AM
Awesome!!!
alaskanbychoice says: Jan 24, 2013. 8:59 AM
I applaud your function, but you can use a spare battery pack on the camera and use the USB port to charge and power the camera.
vkelman in reply to alaskanbychoiceApr 10, 2013. 6:16 AM
Battery pack doubles the time camera can shoot, right? But it doesn't make any easier to attach USB to the camera to use external power source, correct?
zplus (author) in reply to alaskanbychoiceJan 24, 2013. 10:08 AM
Well, to be fair, this is the far cheaper (free vs. $50) option. :)
magno_23 says: Jan 23, 2013. 12:19 PM
you could also go online and search for a 3d printed GoPro 3 Frame
zplus (author) in reply to magno_23Jan 23, 2013. 7:32 PM
Believe me, I thought of making my own frame! But, I decided that the cable mod would be easier and cheaper (free).
santibarraza says: Jan 23, 2013. 2:05 PM
can this work on the GoPro HERO 2?
zplus (author) in reply to santibarrazaJan 23, 2013. 7:30 PM
It looks like the Hero 2 uses Mini-B USB so, yes, in that respect. However, I cannot speak to the clearance/fit because the hero 2 is shaped differently from the hero 3.
mikeasaurus says: Jan 22, 2013. 7:15 PM
Is the skeleton back door waterproof? My GoPro (Hero1) waterproof enclosure has no openings. As a fan of time lapse photography I think this is a great project, thanks for sharing.
Spydamonky in reply to mikeasaurusJan 23, 2013. 1:15 PM
No... The Skeleton backdoor has two massive holes in it! The only way to achieve an extended battery life and maintain a water tight seal, with almost any version of the GoPro, is to buy the battery backpac and the waterproof door that it comes with.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
