So I bought a mass market tomahawk the other day. I'd always wanted one, then stumbled across a website and discovered they were really affordable. About $30 shipped. And several different styles to choose from. I chose a 'Cold Steel Trail Hawk.'
It came in the mail and I was shocked at how BORING it looked. So I decided to make a few changes. And this beauty was born.
(This is my first 'ible. Hope you enjoy!)
Remove these ads by
Signing UpStep 1: Raw Materials
So here is what I got in the mail. A 'hawk with a plain handle (I ordered a spare, too). With the axe head painted black. Like I said.... boring.
First step is to remove the axe head. On my model there was a small hex screw on the side of the head. I found the correct hex wrench and simply removed it entirely. With the encourangement of a wooden mallet, I was able to slide the head _down_ the handle.
Visit Our Store »
Go Pro Today »
Personally, I wouldnt re-use but that it is out of an abundance of caution mixed with the ready availability of cheapie pots and pans. Hit a garage sale, find a junk pot and then you have a dedicated pot you can use for random stuff.
Good question!!
Another related question would be fumes. Boiling vineger didnt smell as bad as I feared. BUT i have no idea what fumes might have been produced from the residue of the paint stripper that was on the head. I did this on the kitchen stove w fan at full blast. Needless to say my wife was not at home. Next time I'd do it outside.
there are two simple methods.
petroleum jelly works fairly well.
the other is beeswax, applied while the metal is warm.
the jelly just adds shine, and rust resistance.
the wax will actually soak into the pores of the metal, sealing it against all but the most inclement of weather.
if you're after a little more color, a few coats of peanut oil to the hot metal will make a wonderful finish.
* "Hot metal" = too hot to handle without gloves. not so hot as to burn THROUGH gloves. somewhere near 160F give or take a couple degrees.
When browning with peanut oil, you're looking to get the steel close to 400F(though it SHOULD work upto 500F+, but leave the windows open), which is just below it's smoke point. Easy to do with an oven :-)
And since you only need the surface(to about 1/8th inch) to be that temperature, most parts can be heated to that temperature in under an hour. Repeated heatings, and coatings will create a darker finish.
