Step 3Add the resistors
According to the USB charging and power spec I should be able to simply short the two central pins (the data lines) and the device will detect that it's connected to a charging device and start charging.
I tried this first of all, but it didn't work (the iPod detected it had been plugged in to something, but refused to charge). I knew the iPod charged from my MintyBoost!, and after a quick look at the schematic and some playing with the multimeter, I decided it would be worthwhile adding a couple of pull-up resistors.
I don't think the values are that vital (the USB spec is quite forgiving), but I decided to try matching roughly what the MintyBoost! was giving, apart from the V+ to D- resistor, which was guesswork.
Don't forget to check that you've got the correct resistance between the pins, and that they're not connected to anything they shouldn't be!
Cell phones don't follow the USB-IF charging spec, either. I'm not sure if anything does. :)
