3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Modify your bike rack to carry a sunfish or other boat
Is your bike rack full of clamps, claws, and cleats that might get bent while carrying your sunfish? Or, is the free boat you found on Craigslist likely to develop another crack if tied down against your rack? Tie a couple of 2x4s to the rack with innertubes and head to the beach!
Step 1Tie 2x4s to the rack
Find some old 2x4s and tie them to the rack with innertubes.
9 comments
Aug 22, 2009. 5:09 PMstickmop says:
As Roverwet hints at, you really need front and rear lines to keep the boat from flying off the racks at speed if one of the cross lines fail. I much prefer ropes and truckers hitches to straps too. When a strap breaks, the ratchet will do a number on your paint.
Jul 12, 2009. 2:10 PMrowerwet says:
need more places to tie off to? open the hood, trunk, doors and look for larger bolts (they hold the important bits on and are attached to the frame securely) get a 1-2" wide nylon strap and melt a hole through about 1" from the end, (a screw driver you don't care about would work, heat it with a torch, or an old soldering iron would also work.) figure how long the strap should be to extend out of the door seam about 6 " and double the end back inside. melt a hole into the strap again, melt the end of the strap so it won't fray and put the bolt through it (you want the hole tight on the bolt shank) push the strap inside when not needed and shut the door.
Jul 20, 2006. 5:41 PMtheRIAA says:
bungie cords > intertubes
Jul 22, 2006. 12:43 PMtrebuchet03 says:
proove it :P But anyways, tubes are great for things like this... $bungies>>$tubes
Nov 27, 2007. 11:29 PMjongscx says:
bungie cord ~= (innertube + woven cover + preformed hooks)
Jul 20, 2006. 11:22 PMranex says:
first person i saw that has my same car down to the interior- nice mod if i had a boat mine is a 1997 with 143,000 miles
Jul 22, 2006. 12:44 PMtrebuchet03 says:
I'm trying to find one... prooving to be a bit difficult... I'd even be happy with a N/A :P But they seem to be great cars :D
Jul 20, 2006. 5:25 PMDanAdamKOF says:
You have an 850 GLT wagon? I have an 850 GLT sedan. Love my car.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
703
Author:ewilhelm
Eric J. Wilhelm is the founder of Instructables. He has a Ph.D. from MIT in Mechanical Engineering. Eric believes in making technology accessible through understanding, and strives to inspire others ...
more »
