loading
This instructable is going to show you a quick process which will allow you to convert a cheap portable cellphone jammer from Chinese frequency's (I think) over to American or other regions frequency's.
Specifically this model from dealextreme.com:
http://www.dealextreme.com/details.dx/sku.4355
  • Important Note: Usage and purchase of this item may not be allowed in certain countries. It is your responsibility to check for your local regulations.
Step 1: Dissasembly of the Jammer
In this step we will simply want to remove the top and bottom plates from the outer casing.
You will need:
- A small phillips head screwdriver
- a pair of pliers - optional
The first thing you're going to want to remove is the three antennas because the top plate will not come off properly with them attached. Next, there are four small screws which hold the top and bottom plates to the aluminum casing, remove these screws and then remove the on/off button from the side using the pliers or your fingers, pretty simple.
Make sure you don't lose the screws, put them aside with their respective cover piece.
Step 2: Removing the Inner Circuit Board and Locating the Adjustable Caps.
In this step we will remove the inner circuit board and locate the caps we will be adjusting.
Once the top and bottom plates are removed the inner board will slide out with some slight pressure. Once the boards out you just want to find the 6 small variable capacitors towards the middle of the board.
Step 3: Adjusting the Caps
In this step you just want to adjust each set of caps until you locate the correct band to block out whatever carrier or network you want to block.
in order to adjust the caps its best to use a small screwdriver, either a phillips head or a regular will do, you don't want to use allot of force here as the capacitors are very sensitive to force and could break.
If you have a frequency counter this step will be very easy as you can precisely tune your jammer, without a counter im afraid its pretty much guess and check. The easiest way I have found to do it is to call a number that continuously generates tones or some kind of audio
and then sit about 15 feet away and slowly turn the knobs until you hear the phone drop out
Here are some useful reference frequencies for tuning.
Cingular 1.850-1.865 Ghz 1.930-1.945 Ghz 1.730-1.735 Ghz 2.130-2.135 Ghz
Sprint 1.865-1.870 Ghz 1.945-1.950 Ghz 1.885-1.890 Ghz 1.965-1.970 Ghz
Tmobile 1.895-1.910 Ghz 1.975-1.990Ghz 1.710-1.720 Ghz 2.110-2.120 Ghz 1.740-1.745 Ghz 2.140-2.145 Ghz
Step 4: Reassemble
In this step you just want to reassemble everything. Start by sliding the board back in, then reattach the top and bottom plates with their respective screws (4 each) next remember to place the on/off button back in its socket, and then finally put the antennas back on ( make sure to put the correct antenna on the correct port).
After you have finished reassembling the unit you may find it annoying to continuously need to open the unit up and re-tune whenever you decide you want to block out a different carrier. In that case you can optionally drill out some small adjustment holes with a small 3/16 size drill bit. Make sure to disassemble and remove the circuit board fully before drilling!
Step 5: Have Fun, But Not Too Much!
Just remember, in most places actively blocking any kind of communications is illegal! so if you plan on using this device make sure you check your local laws and regulations.
EDIT:
Thanks to the guys over at PLA for the method, especially NAK (see you in class dude)
I just got one of these, and the Board looks different than the ones in these pictures (see attached pic). I need help tuning this thing so it at least blocks AT&T and Verizon. I've tried every setting in this thread and in the threads on dealextreme, and none seem to work. I have some questions, such as: What do the hightrim and lowtrim on each variable cap actually mean? Which caps on this new board correspond to which frequencys/carriers? How can I get this thing tuned without a spectrum analyzer or frequency counter? If there's no way around tuning this without a spec. anlyzer/freq. counter, can anyone recommend a good one to buy that will meet the range requirements for the mobile phone? Is there anyone out there that can help me? Please?
try a cell phone shop, tv repair, like a "mom and pop setup. . . private owned.
<p>Even a private shop may tip off the Feds, especially if they deal with customers who come in with &quot;broken&quot; phones found to be working just fine, and those customers are clustered in a particular location. A phone shop will work to keep phones running, not help someone illegally shut them down.</p><p>Keep in mind that Instructables is now owned by a major software company Autodesk, who is a member of the scary copyright group BSA. So certainly they have enough lawyers to know that allowing discussion of illegal activities is not the best idea.</p>
I have the same board very confusing when trying to tune it
Why must fun things be so illegal. In my class one student texts all the time and would love to have one to tick him off with. Then he would be angry with his phone. Pretty much I would use it on only him.
<p>In such a case talk to your teacher. Even absent any specific rules regarding specific devices, there still should be a general clause regarding disruptive behavior.</p><p>Stay away from jammers, as these days mobile phone companies are monitoring signal quality all the time for service anomalies, and will investigate anything that doesn't look right. A phone company actually busted a science teacher in Florida about a year and a half ago.</p>
use a modified annoyatron from think geeks.com . itill do pretty much the same thing, as well as put wierd stuff arcross their screens.
lol in my language arts class almost half the class texts and it would be hilarious for them to not be able to
But what practical use does this have? Anyone who would jam cell phones, is just as inconsiderate as those dimwit cell phone users, who tempt others to use these devices. No one has the right to interfere with the service I and others pay for.
<p>You are quite right, and as such it is quite surprising that Autodesk (a huge US software company that owns Instructables) hasn't taken severe action against the author of this project for their willful disregard for RF interference law, and potentially for the health and safety of those within range of this illegal device.</p>
<p>Excellent Point!</p>
I teach high school and I don't want students texting test answers to one another, You have the right to your service, but not the right to facilitate fraud.
Can't the schools require students to keep the phones in their lockers, during class periods? Can't any phone found in the class rooms confiscated, to be returned only to a parent that goes to the school to pick it up? Respectfully how can the kids learn self discipline, when the adults in their live justify breaking the rules, when doing so makes it easier?
just because you make the rule doesnt mean they'll adhere. i was in high school a few years ago, i can say, most everyone who had a cellphone had it in class, even though they were considered contraband. now that i'm in the military, if you get caught with a phone on you in certain buildings, it's a security issue and it will be promptly destroyed in front of your face. saw it happen two weeks ago to this girl who wanted to text during breaks. they smashed her iphone 4 or whatever the hell the newest version is. im not sure if schools could make this rule though.
Certainly a school needn't to go to the extreme of destroying a phone. Confiscating phones taken into the class room, to be return only to a parent, that went to the school to get it wouldn't be too radical. the adults would be the only ones that would stand in the way of a reasonable action. What happened to the time when caught cheating meant an automatic failing grade on the exam for both parties, and failing the class entirely if the cheating didn't abate?
As long as it is the posted policy they can. <br> <br>Usually 'school policies' are cleared with the districts attorney before posting them.
Don't be stupid, the mobile phone is an invaluable tool to education, I use mine all the time, for taking notes, to even photographing the whiteboard, but yeah, I hate the kids who just go onto fakebook all the time...
Man I'm getting old. No modern whiteboard, we called them blackboards, even if they where green. A cheap snapshot camera was too expensive for most kids to have. No matter taking photos with them was more expensive yet. Not mention actually having the photos of the board would be at least a week away if you lived in a rural town. I agree the phones can be a tool for the students to use, and have to see the degree to what the smart phones will become more useful tools for the students. As a student do you have any recommendations as how to deal with the inappropriate use of the phones in the class room?
I think a bit of common sense is needed with them... Silent mode, full attention paid to the subject of class, and the requirement to put the phones in your bags during tests. If anyone is obviously on facebook, the teacher should proceed to read the contents of the screen out loud to the class, for maximum embarrassment...<br><br>Then again, I am a TAFE student, (the Australian form of College) So phones and other tech are welcomed by the teachers, a zero tolerance high school will not, however...
ditto to that, and amen ! prisons and schools alike should have them, , short range of course. . 1300.00 will do the job. . http://bestgiftsaround.com/Portable-GPS-Mobile-Phone-Jammer-10-Meter-Range-P931593.aspx for 40 http://www.ecrater.com/p/8740566/full-spectrum-cellphone-jammer-cdma 130.00 they get bigger obviously.
I use it for people that are driving and texting. I have to stay pretty close until they give up and put it down. <br>I would like a bit more power/range. <br> <br>This one does not cover all carriers. So far all I know of for certain is Verizon, it kicks me off instantly....
hahaha
You say that now. But try to enjoy a movie with someone behind you so inconsiderate to not put their phone on silent or vibrate. Sorry but that is the kind of person that deserves to get jammed.
“No one has the right to interfere with the service I and others pay for.” You’re right. Like when I pay to go to the movies, or when I pay to go out to dinner. I paid for these services and cell phone use interferes with it. I do not have one of these devices but I can sure understand people that would be frustrated enough to get one. Judging by your comment and self admitted inability to find a “practical use” I can only assume that you are one of those people that obliviously trample on other peoples rights and then espouse to be morally and ethically superior with condescending comments such as this one. "as those dimwit" The bottom line, If everyone would respect everyone else’s rights, their would be no need for such gadgets.
LOL, I didn't say cell phone users have the right to disrupt others with their jabbering. I said they have a right to to have their phone service interfered with with. These devices interfere with everyone's phone not just those, not those annoying others. Ever consider the fact someone may miss an emergency call with one of these jammers in use? I learned long ago not to sweat the small stuff, the dimwits are the small stuff. And I still don't know of a legitimate use for the jammers.
apparently you missed my earlier reply to you. Studetns in school use them to cheat on tests by texting answers to each other. do you think that cheating in school is right , or do you think my using a jammer to prevent cheqating is the legitimate use?
It amazes me how something society didn't have at all nor even dreamed of not so long ago has now become a "must have" and a matter of "life and death". This is as ridiculous of an argument as smokers vs. non-smokers. It's not unreasonable for me to expect others to be respectful enough to not shout or yell less than 12 inches from my ears when standing in line at the store, cell phone or not. The core issue is that people have become self-absorbed and rude; and it's wrong to defend such rudeness by justifying their arrogant and thoughtless behavior with a "right to use something they paid for" like a cell phone. If thoughtless idiots paid a just a little more attention to minding their manners others wouldn't end up annoyed and desperate enough to start packing cell phone jammers. There are two sides to every story...
I agree 100% ajsims! I&nbsp;bought mine only for using at theaters, concerts and dinner. I&nbsp;finally got to use it last week at a 3-D movie. There were about 6 kids within 20 feet of me texting and talking well after the movie started. I reached in my pocket and hit the on switch. It was hilarious to see them all lose their signal and go to the lobby to try and get it back. I really enjoyed the movie and the quiet. I'll do the same next time I fork out 60 bucks for the wife at a nice restaurant and I don't have to listen to the guy at the next table loudly working a business deal on his phone like he wanted us all to hear. Nice and quiet dinner. Ahhhh. I love technology. I will never use it to intentionally cause grief to another person as long as they respect my rights and my space. The argument static has is moot as far as I'm concerned.
Then also blame the Owners of those places. Its not that hard to shield a place so no cell phone works. Put a sign up on the entrance, and its fine (so they know what they're up to) But rigging using a jammer is just as disrespectfull as using a loudass phone in a cinema. Using it in Restaurant (if its on vibrate and doesnt ring) is ok for me. Because if they just talk on a normal loudness level, its the same he would talk to the person next to him. Well i also have it on vibrate in a cinema, like static said, it could be an emergency call or something else really important. But then i would be as silent as it gets when answering, and when its unimportant, just hang up...
I agree with static wholeheartedly. On my campus, there's an entire building where you get no reception. No texting and no calls. Though the latter can be a major peeve, what's the problem with someone silently wasting away in their own domain? The only problem is when they leave that domain and step into your world: and possibly in front of your car. People who are disrespectful are like that inherently. Why not ban them from eating food, because they chew with their mouth open? The same logic applies to a phone: a flawed logic. ajsims- lighten up a bit dude.
It does a wonderful job of running the jabberers out of the restaurant, so that you can have a nice quiet dinner.
TRY AND STOP US BWAHAHAHAHAHA... I mean uh OF COURSE and thats why you should only use them when you can ENSURE you're not disrupting anyones service!... right guys?... guys?
<p>The person who posted this instructable has a profile that says &quot;Phoenix, AZ.&quot; They broke Federal law in three ways:<br>* Importing a RF jammer.<br>* Manufacturing a RF jammer (calibration might count).<br>* Operating a RF jammer (unless this was done completely inside a &quot;Faraday cage&quot; to prevent stray emissions).</p><p>Here is the official FCC webpage on the illegality of cell and GPS jamming:<br><a href="https://www.fcc.gov/general/jamming-cell-phones-and-gps-equipment-against-law" rel="nofollow">https://www.fcc.gov/general/jamming-cell-phones-an...</a></p>
Thanksss
<p>how to block only 3g/4g network ?? email me sir ... mnazarulakram@gmail.com</p>
<p>sir please describe the components of this product</p>
<p>Will this block the signal of Magnus Olsson's covertly implanted brain chip? Maybe this will stop the synthetic voices transmitted to his brain. Since 2011 brain chips have been sold as language translators that communicate through the brain interface, not the ear-drum. They are illegal to install secretly, but are being done all around the world like &quot;Agenda21.&quot; Maybe jammers should be made legal to hinder illegal brian tapping.</p>
<p>Do you have any schematic diagram of this?<br>Thanks.</p>
link is bad, where els can I get this? I really like this instructable.
This is mall mayhem. Everyone's phone stops working. ;D
What about finding larger capacity antenna's to pop on this and make it block cell service in a whole area? Just in theory, expanding the range, by pushing this through a op amp, and pushing it to say, 7 dbi antenna's...like those on a Linksys wireless router? Just curious how far this could actually be taken, and still be portable.
and making yourself a even bigger target. why not just put a red bulls eye on a shirt. and wear that. when yr using the jammer. i kno this being read by the guys an gals at instructbles. so the whole zone 4 jammers should be taken down b4 they end up with a mess on their hands.
What if the inner board won't come out - even with significantly more than "slight pressure"?
there may be screws or little plastic catches holding it in... if not pry it away from the board (in one piece) and make a new container, with perhaps a better aerial!
or they might have crimped the sides of the cannel together. to make it hard to remove the board.
ya mine has no wire so do i need to put one there???????
No wire to/from what?
the red wire kinda in the middle .,
Oh Well if it worked without a wire before then it probly isnt needed.
About This Instructable
231,684views
442favorites
License:
More by Blastwavelabs:Icom Handheld Dual-Band Radio Mod Modifying a Cheap Portable Cellphone Jammer
Add instructable to:
