The first problem may seem insignificant, but it can actually get very annoying. This is because the sound setup on my computer is somewhat finicky, having batteries that can wear out means there is one more thing to check when my sound stops working.
Poor transmitting range is more common and much more annoying. In general wireless headphones work fine if you are sitting three feet from the transmitter. But if you are like me you like to do things while you are using your headphones. Most cheap wireless headphones carry five to ten feet. In my case I wanted mine to carry farther than this, so I added an extra antenna.
So now that you know what we are going to do why don't you go to the next step to see what materials and tools you will need.
DISCLAIMER:
Doing this instructable may conflict with your local communications authorities rules the legality of this is entirely your responsibility.
Remove these ads by
Signing UpStep 1: Tools and Materials
Here are the materials that you will need:
- Wireless headphones and transmitter. All we will be modifying is the transmitter, but ti doesn't do any good to modify a transmitter if you don't have headphones for it.
- DC wall adapter. The voltage you need depends on how many batteries your transmitter uses. In my case my transmitter used two 1.5 volt batteries so I needed a three volt transformer.
- Shrink tubing. This is for insulating electrical connections.
- Solder.
- Antenna. This is for increasing the range of your headphone transmitter. I got mine from an old radio, but you could also get one new.
That is all of the materials you need.
Now for the tools:
- Soldering iron. Solder doesn't do you any good without a soldering iron.
- Multimeter. This comes in handy, but you could probably get along without it.
- Assorted screwdrivers.
- Solder sucker. You may need this if you mess up.
- Wire cutters. For cutting wires of course.
Once you have all of that we are ready to start modifying.
Visit Our Store »
Go Pro Today »
Thanks for your concern.
