Introduction: NEW! Mods for the SCAR 11.01 (the New SCAR 11.02)
These r some mods for Burrito_Master's SCAR 11.01. This will include: a grenade launcher,a hidden grenade launcher, extra mag holder, 27 round mag, a scope, hidden grenade ammo storage, and new stronger handle. I'm now working on a blue rod conversion kit, so u fire the lighter blue rods instead of the yellow/grey rods.
Mods include:
Scope/with mount
bigger mag
new handle
grenade launcher (external)
grenade launcher (internal)
grenade hidden ammo storage
extra mag holder
In the Future:
If you want me to post the rail and strengthened ram please say so.
7/16/08
New pics of rifle (V.2)
Step 1: The New Grip
This is the new grip (its the 1 from Gorkem's rifle)
1- make this
2- attach them together
3- Change to this
4- add the handle
Step 2: The Scope
This is the scope. The scope is 4 pure looks, its not totally on but it is close to where the rod will hit. Its sort of a pain to get on but it looks good.
1- Take off old scope, but leave black/green connectors
2- The scope
3- another view
4- gun mounts
5- all the gun mounts
6- gun rail(make two, 1 for each side)
7- attach to gun
Step 3: Grenade Launcher
This is a grenade launcher that I built (but i didn't design this style) it mounts in place of the front fore grip and can be powerful if you put 2 or more ruberbands on.
1- the complete thing
2- replace peice
3- the grenade launcher frame
4- the ram
5- the mounts
6- fore grip
7- install the ram
8- slide peices forward
9- add fore mounts
10- add grip
11- add foremost mounts
12- mount rear part
13- mount front part
Step 4: Hidden Grenade Launcher
Burrito_Master sent me a message that said that the first grenade launcher was good but it ruined the looks, which I agreed. Now I developed a hidden grenade launcher that is inside the barrel of the gun, and won't effect the flight of the bullets. It uses the same ammo and works similarly to the other but works better and looks better. It has the same type of triger as the fire mechanisim on the rods. It is alot more work than the first but it pays in the end.
1- What it'll look like in the end
2- a close up
3- take off the orange peices
4- this is what it should look like after
5- now build this
6- another view
7- the trigger
8- the main body
9- another view
10- the end of the main body
11- the whole thing (recomend the black rod)
12- build two of these
13- remove one of the orange connectors by mag insert
14- add the main body (the orange connector must swing down not up)
15- feed the string down the body of the gun (mine is by the Gren. Holder)
16- add peices from step 12, replace the orange top peices
17- add the trigger
18- add the handle
19- looking down the barrel (WARNING! Don't do this in real life, wiht real guns for you stupid people!)
Step 5: Hidden Grenade Ammo Storage
This hold the ammo for the grenade launcher. It blends in great with the butt of the gun. U open it buy poping up one side of the new peice.
1- remove top guts
2- make three of these
3- all three (add blue rods)
4- add these into stock
5- another view where to put the orange/brown connectors
6- attach here
7- attach other side
8- how the ammo is put in
9- side view of grenade storage
Step 6: Bigger Mag
This shows how to make the mag longer. In the pics is the 27 round mag, but you can keep adding parts to it to make as long as you want.
1- the 27 round mag
2 and 3- you can either extend it by using blue rods or half circles.
Step 7: Extra Mag Holder
This is a extra mag holder that is mounted to the side of the gun. It allows you to carry a extra mag and switch between them quick. Now b4 u build this, this will take some of the looks away and will add another thing to the side of the gun. It should be far enough out from the other mag, but if its not just send me a comment and I'll fix it.
1- The finished project
2- gather these
3- put these two rods on
4- remove connector
5- add these two rods here
6- build this
7- put a silver spacer and blue spacer onto trigger rod and the extender
8- connecting...
9- u can add silver spacers here
10- and here
11- the thing without the clip
