Modular Cake Box
Published
Introduction: Modular Cake Box
This is a box that accommodates a very large odd sized cupcake cake. It was my daughters wish to have a princess dress cake. Because what else would a 5yr old princess want?
Ok, it's not everyday that you need a custom made box for a cake. But this particular cake :
1 has to be assembled and stored the night before
2 driven a long ways to chuck e cheese
3 be displayed for all of the kids
So....to the wood shop!!!(with finger raised high in the air)
Step 1: Make Up the Platform
This will serve as the serving plate eventually. When finished I will wrap with tin foil.
Step 2: Bottom and Sides
The bottom first. This will serve as the size for every around it. The sides and back will have a 1/4" groove cut in 3/8" for the top to slide into.
The sides alcohol have vertical grooves 3/4" for the front to slide up.
Step 3: Glue and Go
Now that the sides and back are cut to length, glue it up. I lay it out upside down and glue the sides the glue the bottom. NO fancy clamps needed. Just use a pneumatic brad nailer to hold it in place until the glue dries.
Step 4: Front and Top
Now that the frame is constructed the front can be cut. The piece once done will remain removable. Then measure and cut the top.
Step 5: Trim
I added a little piece of quarter round to the front of the front piece. And a piece to the bottom of the top. Mostly decorative.
Step 6: Voila
This is it. Easy peazy. Hope this helps if you're out searching for help
    • Woodworking Contest
      Woodworking Contest
    • Make it Move Contest
    • Casting Contest
      Casting Contest
