This is a hanging lamp made from identical modules. The finished size is just over a foot tall.
It is based on a regular icosahedron, that is made from 20 equilateral triangles.
I made these modules from white card stock. This could also be made from a thin translucent plastic .
The light I used was one I had, a 13 watt CFL equivalent to a 60 watt incandescent bulb.
You will need to use a compact florescent light because the incandescent lights put off to much heat
for this shade.
After I left the light on for a couple of hours the temperature measured inside the top
was about 110 degrees Fahrenheit. The room temp was about 70 degrees, so a 40 degree rise.
This shade weighs less than 3 oz. so I just hung it by the cord, no other support is needed.
The length of the cord is governed by your particular application.
An inline switch is a nice addition to the cord so you do not have to unplug it to turn it off.
Materials Needed
The Lamp Module PDF file
20- sheets 8 1/2 by 11 white card stock
1- lamp socket and cord, an inline switch is optional
1- curly fry light (CFL or compact florescent lamp)
1- 3 inch plastic disc. Cut from a plastic bottle such as milk jug, or a plastic lid from a chip can.
Tools Needed
A printer to print the modules
A craft knife and cutting mat, or if you are really good with them a pair of scissors.
1/4 inch single hole punch or other punch that will reach far enough.
LampModule.pdf211 KB
Remove these ads by
Signing UpStep 1The Modules
Print and cut out 20 of the modules.
The cutting can take some time. It will probably take 2 to 3 hours.
The most important part of the cutting is the intersection of the arcs.
If you use scissors this is the easiest place to make a mistake and cut to far.
This is why I recommend the craft knife and cutting mat.
Start your cut at the intersection and cut away from it in both directions.
The problem is getting a large enough flat material from the milk jugs. Those in my area have large circular indentations in the two large sides opposite the handle. Let me know if you figure a way to use them.
Thanks for the question.
In terms of lantern-making, I find cardstock is not the greatest because it blocks too much of the light and it looks all splotchy. I hear polyester film (i.e. Mylar) is good for this type of thing, but I use laminated photo paper and it works pretty well too.
I agree that card stock is not the ideal material to use but it is readily available and inexpensive so anyone can afford to make this. The ideal material would be a translucent plastic about 10 mil thick.
