3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Modular Hydroponics - Sprouter Modification
This is a modification, very minor, which accommodates growing bean sprouts rather than actual plants.
I have kept the sprouter separate from the reservoir containing nutrient ONLY because I am unsure of the ramifications of eating sprouts grown in nutrient rather than straight water. I am also unsure if there would be any health concerns over using the same water for 3 to 4 days. I did it and the sprouts came out looking, smelling and tasting fine. I know, however, that is plenty of time for harmful bacteria to grow, so if anyone has experience in this area, comments for myself and anyone who might build this would be greatly appreciated. I know that I can add chlorine, but would be interested in any other methods for controlling bacteria/toxins during the growing or washing processes.
Conveniently, many wide mouth plastic containers fit inside a 2L bottle. I chose peanut butter jars for this over a yogurt container, as in Toilet Tank Bean Sprouter, because the water enters the system from the bottom instead of the top. The yogurt container would work, but the 2L bottle would have to be trimmed to the correct height.
Step 1What You Need
What You Need
1 ea 2L pop bottle
1 ea plastic jar that fits inside a 2L bottle - peanut butter jar in this case
1 ea drill
1 ea 1/64 inch bit
1 ea 1/8 inch bit
1 ea utility knife (to cut 2L bottle)
1 ea Modular, Windowsill, Air Powered, Hydroponics Herb Garden/Experimenter
9 comments
Mar 9, 2010. 10:03 AMdolfinmagikpro says:
 You can use a weak nutrient solution to grow those, but before eating them, you should soak them in clean (preferably Distilled) water for 24 hours. The distilled water will "Leech" out the extra salts and you should be fine!
Mar 9, 2010. 10:05 AMdolfinmagikpro says:
 Or, using the drain & fill method, as you are, on the last day before the "Harvest" change to clean water during the drain & Fill.  You wouldn't need to soak them as I stated above.
May 28, 2009. 9:06 AMkennyhaa says:
For disinfecting, you could use a solution of hydrogen peroxide (H2O2), check around the internets for concentration rates. It is perfectly safe to use and is great for the system. The breakdown products are water and oxygen. Any oxygen that isn't consumed by oxidizing (i.e. killing) the bacteria/mold/fungus dissolves into the nutrient solution therefore increasing your DO (dissolved oxygen) content. H2O2 is also harmless to plants at the proper concentration, so your sprouts won't suffer.
Jan 11, 2009. 4:24 PMcynvision says:
This makes me wonder if my special sprout container fits into a 2 L bottle. The instructions for sprouting which come from the website I get my seeds at say that draining well is the most helpful step to sprouts. And they go on about bumping the container around to get excess water out. At first glance this design goes against that advice. But it's oblivious it does work for the seed you're using. I love your designs and maybe if I were giving this a try (like I think I am) I'd want to improvise some sort of air circulation through the system between soaks. Or something to vibrate the bottles? Oh, the ideas!
Jan 9, 2009. 1:23 PMchefmichel says:
Great instructable Wiley ! I was looking for an "easy way" to sprout, as I keep forgetting to wash & drain,and here it is. Simple and effective, all made with recycled elements.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
49
Author:wiley coyote
