3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Modular Magmount LED Lighting
Christmas light bulbs are incandescent and burn out at an ever increasing rate. This was fast enough that my roommates and I got blisters from pulling them. I had those lights up for over two years and I wasn't about to go without ambient lighting. I figured LEDs were the way to go.
Each module is powered by 12V and is relatively simple in concept. The number of LEDs you need per module depends on the voltage of the LED. You'll typically be able to get 3 blues or greens (3.4V each) on a module or 5 reds (2.4V each) on a module. A VERY large number of modules can be powered off of one supply. The maximum number of modules that can be powered by a single supply can handle is its amperage divided by the current a single LED pulls. In my case, I used a 12V 5A power supply from Digium and 20mA LEDs, so that gave me 250 (5/0.02) modules per supply. That's a whole lot of light!
Parts for each module:
A piece of breadboard
3 blue LEDs (3.4V)
A 100 ohm resistor
2 small neodymium magnets
2 ferromagnetic thumbtacks
Other materials:
Soldering Iron
Solder
Hot Glue Gun
Glue Sticks
Speaker Wire
A 12V Power Supply
Step 1Materials and Organization
Your first task is to gather your materials and find the module configuration that suits you. For each module, you'll need some perfboard (the really cheap stuff if possible), a 100 ohm resistor, three 3.4V blue LEDs, two 1/8"x1/8" neodymium magnets, and two ferromagnetic thumbtacks. For general supplies, you're going to need a 12V power supply, some cheap speaker wire, a soldering iron, some solder (lead/tin), a hot glue gun, and some glue sticks to go with it. A third hand pcb holder is helpful, but not required. As for organization on the perfboard, it's really up to you, but I chose long and skinny so my modules would have a similar profile to the wire itself and be less obtrusive.
Once you have decided where the LEDs go, make sure that they are in the correct orientation. The longer lead is positive and goes away from the resistor. The resistor will be the link to the ground for the module. I left a gap between the perfboard and the LEDs so that I could bend them and better distribute the light. Bend the leads that are going to connect toward each other so that they lay parallel and almost touch. The end result of this is shown in the next step.
39 comments
Jan 18, 2010. 1:28 PMmaxwelltub says:
awesome, i love it
Dec 23, 2009. 3:10 AMledlightmaker says:
 I love your idea and design.
Lights along with wall, i suggest a side emitting lights,wich give most lights upwards.
Aug 12, 2008. 10:37 AMInfinityChic36 says:
That turned out really nice!
Another thought for your power supply problem? Who *doesn't* have old power adapters laying around from old cellphones or the like? Just cut off the jack and strip the ends a little bit. *Carefully* check with a multimeter which is power and which is ground (and also how much voltage you are *really* getting out of it). The plug that goes into the wall should tell you it's output - a laptop converter is usually around 16V, cell phones around 5V, old baby swing adapters around 9V. That let's you off without having to come up with a step-down transformer.
You can get screw terminals that should plug into your breadboard and provide a nice safe insulator for the power leads if you want a solder-free project.
You can even cut the power cable within your arm's reach a stick a switch in parallel to control colour, or just on/off.
(I just did this for a lamp with a regular light, manual colour changing via a toggle switch, and a triangle wave generator that automatically fades in one colour, then fades out and fades in the next colour... it turned out really nice)
Aug 12, 2008. 3:32 PMInfinityChic36 says:
I gave the lamp to my friend, (she had one of those paper lantern things). I duplicated it for my fishtank, though. Check back in about a week, after I get it set up (I'm moving this weekend)
May 24, 2008. 12:46 AMxdayz says:
this is great! and even greater if powered by solar energy!
May 13, 2008. 8:22 PMdondangler says:
Just an idea, but you can eliminate the soldering the magnet by soldering thumb tacks on the bread board as well as using them to pierce your power cable. just use the magnets on stick the thumb tacks together
Feb 14, 2008. 5:28 PMFast Eddie says:
Very cool. I want to try this, and have everything pretty much figured out but a few questions:
1- Could you explain your "12V 5A power supply from Digium"? What exactly is that? I imagine its something you plug into the wall and converts 120V IN / 12V OUT? * www.digium.com doesnt seem to have my answer *
2- Also would it be wise to try this without the magnets? Just wrap the leads around the tacks and insert into the wire? I Dont want to burn the house down :)
Thanks
Apr 23, 2008. 6:55 PMBig Bwana says:
Any 12 power supply would work l, like A PC power supply or a walwart even a coleman cooler power supply... No magnets you can solder to tacks ...
Mar 17, 2008. 5:46 PMinvinciblewhale says:
Hi! LOVE the idea! I don't know very much about circuitry or electronics, but I'm trying to do kind of the same thing as these Modular Magmounts - probably not as complicated though, I just don't know much about doing this kind of thing... I was wondering if anyone can help me? Actually for my project, I'm just trying to make an LED string of lights that are different colors. This is to light up a bunch of dioramas in a gallery. I don't actually need any magnets or anything... Anyway I was wondering if it's possible to do that since a lot of the LEDs are different voltages and mcds? And what is the purpose of having the modules on the magmounts? Is it because they're easier to put up together? Or do all the LEDs in the module share the same resistor - and you only have to calculate how much resistance they need for the three of them combined? Can I calculate each LED's resistance needed for every single LED and just give each LED a resistor separately? I am probably going to use about 20 LEDs total. I have a 12v transformer... and I'm afraid of messing up! Should I be using speaker wire too, instead of regular thin wire? Thanks everyone! Sorry for being such a n00by -_-
Feb 28, 2008. 7:33 AMpencilshavingsuk says:
Hey, sorry to sound abit n00bish but what do you do with both ends of the speaker cable? Do you simply connect one end or both to the 12V supply? Just wanted to check as well before i put it all together. Another quick q ... Can you use any bog standard thumbtacks? If not where abouts can i get the ferromagnetic thumbtacks in the UK?
Feb 16, 2008. 12:43 PMmintyhippo90 says:
instead of soldering / hot gluing the magnets in place you could play it safe and just use conductive epoxy
Feb 21, 2008. 9:21 PMmintyhippo90 says:
i think they might have it in the aisle of various adhesives at home depot, but im not sure. Ive never used the stuff myself, it just sounded like a much easier alternative to the haphazard solder / hotglue method you described. you may just have to check around the internet for some..
Feb 21, 2008. 9:23 PMmintyhippo90 says:
btw, i am in love with the whole concept. youre use of the thumbtacks and magnets is inspirational. hopefully my contribution can make youre fantastic idea even better.
Feb 20, 2008. 4:08 PMjoedog86 says:
Clever! I really like the thumbtack + speaker wire + magnet setup.
Feb 11, 2008. 10:49 AMBig G says:
Nice! I'll have to say that thing with the thumbtacks is one of the most creative ways ever of getting power to LED's. :-) You could probably employ this method to do some under-cabinet lighting too, with some white LED's, or even put the LED's in the soffit on top of the cabinet (if yours has one) for a more "ambient light" look, without having to look directly at the LED. That would look pretty cool! But overall, great instructable! (clicks on the +rate button) :-)
Feb 11, 2008. 3:59 PMjfc443 says:
sorry if sound bit dumb bout this, but hey im only a teenager lol and it myt help. but yer anywayz i hooked up some colour changing LED's to my stereo system and you need to crank it up quite abit to get a decent pulse, but hey lower voltage LED's myt work a treat, let me know if you try would love some feedback on this idea.
Feb 12, 2008. 2:05 AMjfc443 says:
I tried both and they were both effective, I also tried hooking them up to where the speakers were plugged in, just to test it out but the speakers drained it to much. but I think its best to dedicate them to another output channel for a better quality of sound.
Feb 17, 2008. 9:42 PMWilderLust says:
be careful! you need to make sure your impedances match. stereos are setup to have 4 or 8 ohm loads for speakers. there are many different types of stereos with various levels of toughness but the amp circuit can eventually fry on you if you get too far out of its specs. you can make music light drivers with a few opamps and isolate the device from the stereo to be safe. and by the way... i started electronics before i was a teenager so "just a teenager" is the perfect time to get into electronics :-) cheers, WL
Feb 18, 2008. 12:50 PMjfc443 says:
okies thanks for the advice, will bare that in mind.
and about the 'just the teenager' bit... I've been into electronics since I was little and im nearly 16 now lol, I just thought I would cover my ass as i know there's alot more experienced people out there =p.
cheers
Feb 15, 2008. 10:30 AMGitarGr8 says:
Cool idea! My only suggestion would be that you use a light diffuser so that you don't get the ring of light pattern. Simply sanding the LED does wonders for this.
Feb 14, 2008. 1:02 PMThe Expert Noob says:
oOo!!! Im so bookmarking this instructable. My Idea will involve the RGB LEDs. I would have to find some 4 conductor wire, but 4 magnets per module might get expensive, so I may use a 4 conducter, crimp on computer connector to quick connect the modules. I will use a microcontroller w/ PWM (color changing) and trasistors (for amp load) to create 256R x 256G x 256B to create 16777216 colors. All LEDs are not created equal tho. so I may step it down to 16x16x16 colors, but you get the concept.
Feb 15, 2008. 3:42 AMBytePilot says:
http://www.emagnetsuk.com/circular-disc-magnets-9-c.asp
Less use to chaps overseas but a decent magnet supplier in the UK.
I'm not affiliated with them, but they've served me well in the past.
Feb 14, 2008. 1:14 PMshaulfriedman says:
just what I was thinking! put some RJ11's on both ends of the module and you good to go! i know asm for pic but have never played with PWM so hit me!
Feb 15, 2008. 10:42 AMThe Expert Noob says:
This is for the <a rel="nofollow" href="http://www.avrprojects.net/articles.php?lng=en&pg=53">ATMega8</a> PWM RBB LED Controller<br/><br/>also this is what I am going to base mine off of<br/><a rel="nofollow" href="http://www.semifluid.com/?p=8">PIC12F675 Single RGB LED Controller</a><br/><br/>You can also control it via the serial port on a computer using the persistence of vision and turning on the LEDs one by one (of RGB) and deciding the intensity by just one byte at a time! A simple program can be written in basic joined with a chip that sends each byte (1,2,3,1,2,3 aka R,G,B,R,G,B) for each byte it receives.<br/>
Feb 14, 2008. 10:46 AMwaterppk says:
Very cool. I had lighting like this in my house last year because my stupid room mates would leave the lights on constantly so I put LED lights everywhere so they would have no reason to turn the lights on when they walked through at night. The thumb tack idea is genius though :) If you live near a harborfreight store you can get the 2 wires speaker stuff really really cheap, you can order LED's from All Electronics.com for cheap too :)
Feb 14, 2008. 11:48 AMtrixcomp says:
Hey! your room mate was stupid aye! that hurts bro... but not as much as stubbing my toes because I could see what i was doing under the red led light :-).
Feb 12, 2008. 3:11 PMGorillazMiko says:
Wow! That's really cool! I would like to do this to my room, that would be sooooo cool. +1 rating.
Feb 11, 2008. 12:36 PMBig G says:
Thanks! I work at a lighting store, so the under-cab light was one of the first things that came to mind. :-)
That, or a sweet home stereo dance room with a whole bunch of these, with a sound activated switch so they pulse to the music...now that would be cool. But probably wicked expensive...
Oh, and congrats on getting featured!
Feb 11, 2008. 1:45 PMBig G says:
Sorry for the double post, but something just struck me, in reference to my aforementioned stereo system. Since you use speaker wire anyway for the power, if you hooked up the wire to a speaker, then put the LED's on the speaker line, theoretically, the LED's would pulse to the music, because the "sound" going through the speaker wire is really pulses of electricity....you could even hook the LED's up to the subwoofer line and have just the low notes pulse..... Maybe I'm completely mistaken, but that would be cool if it worked. Just a passing thought. :-)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
5
Author:opticron
