3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Modular Paper dodecahedron
This is based on the work of George Hart (www.georgehart.com). But I'm not using his templates :).
It is donde with 20 equal equilateral triangles, you need at least 5 colors so you don't get two triangles with the same color together.
Step 1Making the triangles
So, we need 20 triangles. I used 5 square pieces of paper of different colors, I found that the configuration of the picture maximizes the size of the triangles with a side length of (square side)x((3-sqrt(3))/2).
One way to construct the triangles is first drawing an equilateral triangle with the same side length as the square and taking the distance from the top vertex to the center of the square with a compass.
Then mark that distance from each vertex of the square to the side on its right (clockwise).
Again with the compass take the length from the other vertex to the mark you just did.
Now you have to make the triangles with the length you have with base on the sides of the square as they are on the picture.
Now you cut all the triangles :D.
9 comments
Mar 19, 2012. 5:14 PMjfields2 says:
well i got every cut out and all the slits cut but now im confused on how the pattern goes all the way around. So if possible next time you create something it would be nice if you went through all the steps.
Aug 29, 2011. 8:08 PMKinky169 says:
I've spent almost an hour on this step (assembling 5 triangles) and am not able to get it to work. Using your first picture on this page as an example my orange and blue triangles fold flat together and my green and purple triangles almost lay completely flat with each other. Making the shape in the center a rectangle with triangle top instead of a a pentagon. I also had my bf try without any instruction from me, just showing him your instructable and having him figure it out and he ends up with the same thing. I also had him check to make sure I did everything right.
I originally only cut the slits with scissors as far as the width of the slit goes since I could always make them larger. When I ran into my problem I would cut the slits just barley wider and trying it again and again but still can't get it. This was the only issue I could think of. I might be able to go wider but I doubt it'll hold itself together without glue which wouldn't be easy to use and not have it be seen.
The only differences between mine and yours is I cut my slits on the opposite side and my triangles are a little larger. They were all carefully measured and cut.
What is it that I'm missing here? Thank you ahead of time for any advice/help you can provide :)
Jul 24, 2011. 2:07 PMEleniel says:
hey there. what happens between the two last pictures? at that point there is about 10 triangles left and i am not sure how it goes. think you could add this in for clearance?
Jul 17, 2011. 10:55 AMtigerbomb8 says:
nice.
i might make one out of sheet metal
Jul 17, 2011. 11:48 PMtigerbomb8 says:
challenge accepted
Jul 19, 2011. 8:47 AMPaulnt says:
I'm curious as to how this would work? I know when I built mine I needed the flexibility of the card to get the last piece in. Would definitely be impressive in sheet metal though.
Jul 17, 2011. 11:51 AMluc.dof1 says:
Splendid !
Jul 17, 2011. 11:25 AMChrysN says:
Nice!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
4
Author:Pepe_91
