3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Modular, Windowsill, Air Powered, Hydroponics Herb Garden/Experimenter
Although this is an evolution of previously entered work, there has been significant changes to the whole modular idea as well as some control mechanisms added.
I have learned along the way that the back flow of air through the pump IS definitely a problem, especially when working with air tight systems or relatively low height water columns. For this reason, I have added two mechanism to aid with the control of the fill and drain cycles. I have also added a central "manifold" through which all air flows, allowing for expansion/experimentation.
The air escaping through the planters, when the reservoir empties, was also a problem, so I added a separate bottle that I call a bubbler. The bubbler redirects the escaping air and reduces the bubble size, reducing splashing, vibrations and effectively extending the pump on time. I suppose it could be used as a planter as well. Don't know what you'd call the bubble method.
The MODULARITY has been expanded so that the "HUB" of the system is the Bubbler and the TEE below. Everything else is swappable. You can change reservoirs and/or reservoir types as well as "planter lines" and types of planters at your whim. This allows for experimentation and expansion without having to disturb that which does need to be disturbed.
I do plan on improving/screwing with stuff as time goes on and required a "productive" window sill garden that accommodates different designs and methods, without starting from scratch each time. This what I've come up with and hope to be adding "Modules" as time goes on.
Step 1Modular Reservoir
Modular Reservoir
  • last photo ←
WHAT I USED
1 ea 2L pop bottle with cap
Approx. 18 inch length of 3/8 inch OD Vinyl tubing (trim as required in final setup)
1 ea 7/8 inch length of 7/16 inch OD tubing
1 ea 5/8 inch length of 1/2 inch CPVC tubing
Hot melt glue (Silicone would probably be best)
WHAT I DID
1. Drill one each 5/16 inch and 13/64 inch holes in the cap as shown.
2. Cut both ends of the 2 ft length of tube on an angle as shown.
3. Thread the 2 ft length of tube through the 5/16 inch hole in the cap as shown.
4. On the end of the same tube, that will be outside of the bottle (cap orientation), slip the 7/16 and 1/2 inch pieces over each other as shown to form an adapter.
5. This adapter will leak without tension applied, so hot melt glue as shown to seal.
5.Place cap on bottle and adjust tube so it reaches the bottom of the inside of the bottle.
29 comments
Oct 21, 2011. 8:12 PMmkimmerle says:
How much would you say this would cost assuming you would use recyclables for the bottles?
Jan 27, 2009. 9:10 AMGroove22 says:
Would there be any way of making the system automated? It would be nice to have the pump kick on at preset times through out the day and shut off after X amount of minutes
Jan 15, 2009. 6:33 PMrunningman53 says:
Being ignorant in this field I have to ask what is the purpose of having to move the water from one bottle to another and then back again? Couldn't you just bubble it where it's at? And to what advantage does one get by doing this verses planting in the soil and not useing any energy?
Dec 18, 2008. 3:17 PMprox says:
what is the bubblers purpose? is it a place for the air in the resevoir to go when the water returns? does the bubbler eliminate back flow into the air pump? this is my main concern. ps. very cool, ive been trying to come up with something similar without much luck.
Dec 19, 2008. 6:09 AMprox says:
gotcha, thank you. one think to consider and you mention it--aerating the resevoir water, the oxygen being good for the roots. i think simply running the air pump hose into the resevoir water should do the trick. what do you think?
Dec 17, 2008. 1:35 PMbwpatton1 says:
Three questions 1. Do you have any new modules b/c i am interested to build them. 2. Could you post an instructable about a larger system you talked about. I think I would like to line my room with plants :) 3. What kind of nutrients do you use, I am relatively new to hydroponics and could use a few tips.
Dec 15, 2008. 5:23 PMawakebyjava says:
Have to be honest man, you lost me on this one.
Dec 7, 2008. 7:28 AMchucky705 says:
Very nice I built a 14 plant system that uses a cheap pond pump almost the same with the 2l bottles but out of 1 inch pvc with a 30 gallon drum for the resivor sorry about the spelling. yours is very cool
Dec 6, 2008. 4:24 PMtabletopphoto says:
Have you tried bigger reservoirs like 10 gallons or bigger?
Dec 5, 2008. 1:38 PMtabletopphoto says:
It would be so nice to see a video of that working. I just don't get it.
Dec 5, 2008. 11:32 PMtabletopphoto says:
Okay. I'm starting to get it. Atleast I believe I am. The dwc is a means to reuse air that would other wise be lost. That is efficient.! 'm not a person who can read plans well and actually need to see the finished product in action to completely understand. I hope you could post a video showing the whole system in action, and for those of us who start out a bit slow, explain what is going on. That would be really useful for pple like me who don't always get something unless you draw us a picture (or vid) Thanks again! I appreciate.
Dec 6, 2008. 4:23 PMtabletopphoto says:
I'm kinda suprised that the plant doesn't drown in the DWC since it only gets air durring the cycle. The pump runs how many times a day?
Dec 5, 2008. 3:49 PMnolte919 says:
I have to say I am quite confused which is a shame because you definitely have something spectacular going on here. First of all I don't see the point of the DWC at all. It looks like a complicated way of letting air escape. And why did you put a hole in the side when you could just have easily put the tubing down the neck that's wide open. And why did you attach tubing to the bottom of the DWC. You mentioned draining and checking the level in there but can't you just look at it and tip it upside down to drain? That tubing at the bottom seems like a leak waiting to happen. And why does the DWC need min and max level markers? If air is just bubbling through it how would the water level ever change? Also, I don't understand if air pressure is rising, pushing up the water in the planters, why would the bubbles be decreasing in the DWC? Wouldn't you get more and more bubbles as the water level in the planters increased? You've clearly put a lot of effort in explaining how you built everything and did a wonderful job I might add. But maybe a little more explanation as to why decided to do some of the things in the first place. I understand the bubbler just not the DWC. I don't mean to be a downer. I actually think this project is brilliant and I don't even know what that DWC is for. After I figure that out I'm sure I'll be blown away.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
49
Author:wiley coyote
