Step 5Manifold Assy
Please note that a gang valve, with it's individual line controls, would be preferred for multiple lines, but for those who do not require such controls................
WHAT I USED
1 ea several inch length of 1/2 inch CPVC tube
2 ea end caps for same
1 ea 13/64 inch drill bit
1 ea 1/64 inch drill bit
1 ea small, self tapping screw
Air tubing as required during assembly
WHAT I DID
2. Install end caps on each end.
1. Drill 1 ea 1/64 inch hole, near one end, into, but not through tube.
3. Tap 1/64 hole using small, self tapping screw and screw in fully when complete.
1. Drill 3 ea 13/64 inch holes into, but not through, tube as shown.
3. Insert aquarium air tubing securely into holes as required.(not shown)
PRESTO - A one input / two output (at least in this case) air pressure manifold with a passive, adjustable, pressure relief valve. Please excuse any incorrect terminology. Additional holes (ports) could be added as required until maximum air usage limit is reached or reservoir no longer empties completely.
Add Comment
