Well, here's a very DIY, cheap an recyclable method to make molds for relatively low temperature casting.
Remove these ads by
Signing UpStep 1Materials
Gelatin -- I'm using Jello
Water
A vessel to pour in that will hold your positive item
Mixing container
Mixing Stick
A refrigerator with space for your vessel
You may need:
Skewers or other support device
Hot Glue
Tape
You probably want:
Chap Stick or Vaseline (chap stick being "edible")
Personally, I'd use alginate. It's a fairly common life casting mold-making item which should satisfy your "no weird mold-making stuff" requirement.
Douglass and Sturgess has it - it's called Dermagel (the same stuff used by dentists to make molds of your teeth):
http://www.artstuf.com/DStockNEW.fm$RETRIEVE?sortcode=BC030728&html=display
You can also use Moulage - which is basically like Jello and reusable ;)
http://www.artstuf.com/DStockNEW.fm$RETRIEVE?sortcode=BC030733&html=display
No worried about living in a small or even tiny town... You have internet access, so you're not so remote that mail can't get to you ;)
