Molotov Lantern
Introduction: Molotov Lantern
Outdoor Workshop Contest
Second Prize in the
Light your patio and keep the bugs away with these quick, easy, and attractive bottle lamps.
bottles (beer, wine, liquor, soda, whatever)
tiki torch wicks
2 - 1" wood screws
pipe mount hardware (I had to go to a construction supply store as opposed to the average hardware store for these, but the guy at the hardware store told me where to find them.)
2" threaded rod (that fits the pipe mount hardware) I bought a 12" rod and cut it into 6 pieces with a hacksaw.
large wood bead (This is optional but makes the hardware more attractive.)
tiki fuel
1/2" - 3/4" copper coupling
aluminum tape (maybe-depending on the size of your bottle)
plastic/rubber tubing
Step 1: Mounting Hardware
1. Mount the plate
2. Screw the bead onto the middle of the rod. Some of my beads gave me trouble wanting to go onto the rod. If you screw the rod into the plate and then put the bead on while it's mounted, it will go on easier. This bead is decorative, but it also acts as a nut to keep the rod and bracket from swiveling if it is put on tightly.
3. Screw the bracket onto the rod.
Step 2: Adding the Wick and Filling With Fuel
1. Slide the wick into the copper coupling by pushing it in from the larger end.
2. Fill with tiki fuel.
3. Fit copper coupling into the mouth of the bottle. If it's too small, use strips of aluminum tape to bulk it up.
4. Cut a piece of the tubing to fit the neck of the bottle. This will allow you to get the clamp tight without putting too much pressure on the bottle and possibly breaking it. (Thanks Reengineered for the idea) I had some lying around the house that was just a bit too small so I cut two pieces to make it all the way round, but if you bought tubing for this project you could buy a size that would fit better.
5. Sandwich the bottle with tubing into the bracket and tighten.
Step 3: Ceramic Plate
For those worried about the surface you've mounted these lanterns to, you can add any kind of protective plate from a piece of sheet metal to a decorative plate as I've done.
1. Mark the center of the plate with a marker.
2. Begin drilling with your ceramic bit following the directions on the packaging. I did mine in the sink with a small board underneath so that I could cool the bit down from time to time.
3. When you've breached the other side, flip the plate over and drill from the other side for a quick finish.
Note: If your plates are porcelain, these bits will be chewed up quickly. Choose ceramic plates or get a bit made for porcelain.
4. Use a screw to mount the plate behind the wick. Be careful not to over-tighten. It will break the plate.
Step 4: Hang, Light and Enjoy!
1. Loosen the bracket.
2. This is where I needed a friend. One person needs to hold the bottle while the other tightens the bracket around the bottle.
3. Light and enjoy your patio's new bug free ambiance.
    • Paper Contest 2018
      Paper Contest 2018
    • Pocket-Sized Contest
    • Science of Cooking
      Science of Cooking
    Looks great, simple, elegant, functional. One improvement you may wish to make is the addition of a rubber pad (bike tire tube, weather stripping tape, etc.) between the clamp and the bottle. Having experience with mounting glass to metal, the two do not typically expand/contract at the same rate with temperature which could cause the glass to fracture with temperature change. Adding the flexible pad in between will allow for this difference. If nothing else (risking sounding like a safety whiner) you might add a note about not over tightening the clamp and/or leaving it loose with the rim of the bottle supporting the weight.
    That's a really great recommendation. It would have to be pretty as well as functional. I'll look around at the hardware store and add that when I find something I like. Thanks!
    Really I think you could do it so that it wouldn't even be visible. If you just apply it to the jaws of the clamp you wouldst know it was there. Personally I think I would cut a nice strip of inner tube and wrap it neatly where the clamp is. The tube is black and I think it would accent the hardware if it is left a little exposed. when you go shopping, just remember, the main idea is to provide a little cushion and distribute the clamping pressure. Any time you have metal against glass it creates a point load that is bad. If your chosen material is squishy like a sponge you would need something thicker, if it is more like tire rubber you can get away with something thinner.
    I found some plastic tubing in my piles of random stuff from other projects that worked great!
    Thank you for this excellent idea. To satisfy the paranoid few, you could always add a shield behind the wick. Plumbing clean-out covers are stainless discs that would not only shield the flame, but would act as a reflector as well.
    I have bowed to the peer pressure and added some protection for the wood. See the new Step 3!
    Yeah, thanks for that. The photo in the email was making me nervous. Even though it is impossible for a flame that size to ignite the post at that distance, weird stuff happens.
    Due to various comments, I have edited step 2 to include a copper coupling to hold the wick. Safety first.
    Just in case I can't remember this tiny factoid when I go to the store to get the parts to build one of these: the base that's screwed to the wood is called a rod hanger plate.
    A substitute for the aluminum tape could be copper tape. The kind that is used to wrap around trees as a snail barrier.
