Safety First: Molten anything can cause severe burns. Anytime you use a flame make sure you’re in a well ventilated area and that you’ve taken fire safety precautions. As always, be careful and work within your experience.
Remove these ads by
Signing UpStep 1Cut some rings
Use your desired size socket bit to wrap wire around it. Snip a full circle out of the coil and file the edges so the ends fit together nicely.
For the pendant I’m making do it twice.
Been collecting a few small tools, should be able to work on one of your projects pretty soon now!
Im still unsure if there is a difference if I use a Non-lead 95% tin Solder than on with Silver.. If someone knows, it would be nice to know the info..
Anyways, hope to make my first instrutable or video about how I try to do some pendants..
Thanks Mrballeng!
The above web site is about toxic zinc exposure from Galvanized steel!
You should also note that most solders people would use for this type of work melt below 840 degrees centigrade, zinc boils at 900. Besides, soldering should be done in well ventilated location so fumes can't accumulate.
I'm not saying to throw all caution to the wind, but look at all sides of a debate. Only then can one make an informed decision.
Too much of anything can be dangerous, but the only toxic chemicals you should make all efforts to avoid are dihydrogen monoxide, hydroxic acid, hydroxylic acid, and hydrogen hydroxide. Don't get me started on how hazardous those things can be! The worst part is we are surrounded by them...
P.S. Great job Mrballeng!
what you say is true, but if anyone decided they are going to constantly use metals for jewelry making other than gold or silver because they are cheap then you shoukld at least be aware of some of the dangers involved in doing so. Also if you decide you can make and sell a lot of cheap jewelry to make extra money or a living then you should make sure of ALL the dangers involved.
People DO develop sensitivities to copper, brass and zinc and if someone that you sold this jewelry comes to you demanding to know whay they had to spend a lot of money at the ER to treat an unknow sensitivity to zince what are you going to do if they demand that you pay for the expence???
TO be knowledgable and understand about these issue is a good thing for more than just one reason. I have several books on jewelry making and the Better books go over some of these issues. But none of the jewelry books I have deal or talk about making jewelry from galvinized wire or its possible safty issues.
Galvinized metal is iron/steel that has a coating of zinc metal on top to keep it from rusting.
Heating ANY Galvinized metal WILL Create Toxic FUMES that can KILL YOU!!!
See the below web site citation!!!
http://www.arador.com/articles/galv.html
Or just do a search using the words " heating galvinized metal/steel"
You are better off using copper/brass or any plain steel that is NOT coated with Zinc or any other protective metal!!!!
Zinc oxide makes a good sun screen but the fumes from heating Galvinized Metal will and has Kill Others!!!!
And enven inhailing fine zinc particle via filing down the rings exposes you to the zinc. Also if you or anyone decided to use zinc coated wire to make a lot of objects / jewelry to wear thant means a lot of flame soldering/ filing not to mention wearing your own creations. Just like people have skin sensitivity to copper and brass they can also develop a skin sensitivity to wearing items make or coated with zinc...
And say you sold of give this to someone and they end upn developing a bad case of skin sensitivity what will you do then..? What if They decide they want recomensation SP? for the time and expence it cost them to go to the Dr or say the EM Room at the local hospital???
I have taken some jewelry making courses, and the teacher did go over some of this... Long term exposure to certain heavy metals is Not a good thing! Most how to jewelry books go over making itens out of gold, silver and there is a reason for this there is little if No toxicity cause by these metals. Certainly jewelry made of copper, brass and modern lead free peweter are alson talked about by older books and some the the better newer books do talk about toxicity and sensitivity issues...!
No one ever talk serriously in the classes I took, or in the books I own about making jewery from galvinized wire. Certainly makeing jewelry from galvinized wire/ metal is an attractive and cheap alturnative to silver, copper and brass but people should at least be aware of the possible dangers of using, open flame soldering and wearing such jewelry.
To be warned and to be aware of dangers is a Good thing, and that is my purpose
