Step 2Cutting the Fabric
Measure from side edge of your fabric 18 inches and mark in a few places.
Cut the fabric out (you will end up with a 30inch x 18inch rectangle that is folded in half)
Repeat that process for your fusible fleece, and lining fabric.
Using the same process, mark your coordinating fabric. Measure and fold up 7 inches and make it 18 inches wide again. (Leaving you with a 14inch x 18inch rectangle that is folded in half)
Lay your 4 cuts on top of each other, lining up the folds. Pin corners together. Measure and mark a 3 in X 3 in square out of the 2 corners on the fold. Cut out the corners. (I use sharp scissors and cut them all out at once. You may want to cut and measure them individually)
Cut an 18 inch by 11 inch rectangle out of your lining material and your main fabric material.
Cut a 10 inch by 12 inch rectangle of lining material.
Cut a 18 inch by 10 inch rectangle of lining material.
Cut a 22 inch by 10 inch rectangle of lining material.
Cut 2 two strips both the main and coordinating fabric that are 4 inches by 30 inches.
Cut an 18 inch strip of elastic.
Hand tired yet? That was a lot of cutting.
Add Comment
