Money Belt
263
Published
Introduction: Money Belt
Do you ever worry about your valuables whilst on holiday or simply taking a trip around your home town?
A back-pack can be easily accessed from behind and a 'bum bag' is often an uncomfortable bulk around your waist. This subtle money belt is the perfect solution. It is simple to make, can be styled to your own comfort and is adaptable to your personal needs. Made from thin fabric, this belt can fit secretly underneath any outfit. You'll never have to stress over your important items again!
Step 1: Collect Materials and Equipment
MATERIALS:
Fabric
Velcro
1 x Zip
Thread
EQUIPMENT:
Fabric Scissors
Pins
Step 2:
Collect your fabric and the fabric scissors.
Step 3:
Iron your fabric to remove any creases.
This will ensure that you are able to cut accurately sized pieces in the next step.
Step 4:
Measure out two rectangles, a little bit larger than the size you want your final pouch to be.
This can be done in two different ways. Either draw the rectangle onto the fabric using textiles chalk or use a paper pattern.
Step 5:
Using the fabric scissors, cut out the two rectangles.
Step 6:
Fold over the top of each rectangle, as shown above, and iron to hold in place.
Step 7:
Collect the zip and the two fabric rectangles.
Position them as shown above.
Step 8:
Flip the rectangles over so that the folds are against the table.
Step 9:
Place the edge of the rectangles with the folds onto the zip, as shown above.
Pin into place.
Step 10:
Using the sewing machine, stitch along the line of pins on both sides of the zip.
Step 11:
Collect your fabric and the fabric scissors again.
Step 12:
Iron the fabric to remove any creases.
Step 13:
Cut a long strip of fabric, twice as wide as you would like your final strap to be.
It should be long enough to fit around your waist and overlap with the pouch slightly.
Step 14:
Fold the fabric strip in half width-ways and pin along the edge that is opposite to the fold.
Step 15:
Using the sewing machine, stitch along the line of pins.
Step 16:
Turn the strap that you have created inside-out.
Step 17:
Iron the strap flat so that the seam sits along the bottom, as shown above.
Step 18:
Collect the strap, the zipper and pins.
Step 19:
Line one end of the strap up with the side of a fabric rectangle, as shown above.
Fold the rest of the strap up so that it all sits on top of the same rectangle.
Step 20:
Fold the top rectangle over, so that it lines up with the bottom rectangle.
The strap should remain on the inside.
Secure into place with pins.
Step 21:
Using the sewing machine, stitch around the edges of the pouch.
Ensure that the end of the strap is sewn into the seam as well.
Step 22:
Using the fabric scissors, cut the corners of the pouch off, ensuring that you do not cut the seam.
This will ensure that the corners of your pouch are sharp.
Step 23:
Fold the pouch inside-out.
Step 24:
Fold the loose end of the seam into itself and pin to secure.
This will ensure that this end of the strap does not fray.
Step 25:
Collect your pouch and the velcro.
Step 26:
Cut one piece of each side of the velcro, long enough to extend the width of the strap.
Step 27:
Pin the rough side of the velcro to the end of the strap.
Step 28:
Using the sewing machine, stitch around the square of velcro.
Step 29:
Pin the soft side of the velcro to the side of the pouch.
This should be the side opposite to that which the strap is already sewn into.
Step 30:
Using a needle and thread, stitch around the edge of the velcro square to secure in place.
Step 31:
Fasten the velcro and your Money Belt is complete!
    • Casting Contest
      Casting Contest
    • Make it Move Contest
