Introduction: Monicas Peephole Frame - F.R.I.E.N.D.S
The frame around the peephole on Monicas door is recognisable to any fan of Friends, I wanted one for on the door of the flat I move into next month but wasn't willing to pay £30 for it because I'm a cheapskate...
For this tutorial you will need:
Materials;
= A few sheets of cardboard
= PVA Glue
= Kitchen Roll or Tissue
= String
= Yellow Paint
= Varnish (preferably matt depending on how you want your end product to look)
Equipment;
= Craft Knife
= Paint Brush or Sponge
Optional;
= Darker Yellow Paint
= Cotton Buds
= Super Glue
Step 1: Cutting the Template
The first thing to do is to find a decent image of the peephole frame.
I used the one on this link
http://blytheponytailparades.typepad.com/.a/6a0154324516d9970c01538f17f0bc970b-500wi
You don't have to do this but it helps. Print the image off as big as you want it then you can stick it to the first sheet of paper as a guideline for where to cut out with the craft knife.
After cutting out the first one you can use that as the template for cutting out the shape again on the other cardboard. The number of layers is up to you, I used 3 sheets but you might want it thicker or thinner depending on how thick the cardboard is. Stick them together
Step 2: Making It 3D
Using the craft knife, gouge out the sections that are meant to be the deepest.
Then glue the string over the sections that are meant to be the highest, the swirly bits can be a bit fiddly. I used super glue to stick the string down but I imagine that PVA glue would work fine, it would just take longer to dry. (I forgot to photograph that bit)
Then Paper Mache the whole thing, do as many layers as you think it needs. I did about 2 and a half layers, make sure you don't loose the shape and the grooves of the frame.
Step 3: Painting It
Before painting the whole thing yellow I made the grooved bits stand out more by using the darker yellow paint.
Paint the whole thing yellow.
Step 4: Varnish It
After waiting for the paint to dry, varnish the whole thing so it wont flake paint on everything. I used gloss varnish because it was all I had in but I think it made it a little bit too shiny so you might be better using one with a matt finish.
Find your own way to stick it onto your door. Because it's only cardboard and paper mache it isn't very heavy so you could glue it on. Another way you could attach it is to put a pin or a nail in you door so it sticks out a little bit and make a hole in the back of the frame and hook it on.
I hope this tutorial has been helpful :)
Sam.
