Monsta X Kihyun Arbour Day MIniature Small Plants
Published
Introduction: Monsta X Kihyun Arbour Day MIniature Small Plants
It is currently still unfinished, the instructable will give instructions on how to make the pot and soil/stones
Step 1: Materials
- Paint
- Black
- Green
- Grey
- Red
- Blue
- White
- Brown
- Cardboard
- Any container
- Rising Star has a rimmed pot, Mon-Love has a verticle pot
- Cardboard + Rim of paper cup = base plate
- Cork + Sand = Soil
- Cork + Rocks = Stones
- Pencil + Elastic = Bamboo base
- Paper + Paint(+Mod Podge) = leaves
- Skewers/Wire + Paint = Twigs
Can be made out of anything, use anything you can find from foam to string, the list is of things that I used...
Tools : Scissors, Hot Glue Gun (melting plastic), etc. (unfinished)
Step 2: Containers
(This is for the type that I'm using)
1. Use a hot glue gun to melt the top of the container, remove the narrow piece
(Opt. Heat a baking pan upside-down on medium heat stove and melt the rims of the containers to get a smooth finish)
2. (View next step) Mix paint on the base plate, paint the containers and place containers on base plate -> Green, Black, Grey
3. Mod Podge two layers/coats
Note : I realized later on that Rising Star has a different pot than Mon-Love, to accomodate for this, I removed the container from the base plate and replaced it with a biodegradable pot (painted in the same colour)
Step 3: Base Plate
1. Trace out a circle
2. Cut out a rim (can be from a cup, like what I did)
3. Glue rim on base plate, using binder clips to keep in place while allowing it to dry
4. Mix paint on the base plate -> green, black, grey
5. Paint then mod podge two layers/coats
Step 4: Soil
1. Crumble cork
2. Mix sand with cork
3. Add paint and combine/mix -> black, brown
4. Let dry
5. Place in Mon-Love's pot
Note: At first I thought Rising Star's pot was also filled with soil so I ended up making too much fake soil, I could add it to the bottom of Rising Star's pot (so that it is not visible), but I decided to save it for a different project
Step 5: Stones
1. Cut cork into cubs and triangles
2. Paint black
3. Mod Podge over top
ALTERNATIVE
1. Gather or buy small rocks
2. Paint black
    • Backpack Challenge
      Backpack Challenge
    • BBQ Showdown Challenge
    • Stick It! Contest
      Stick It! Contest
    2 Discussions
    Will you be putting plants or seeds in the pots?
    No. I intend to use skewers and other materials to make the plant.
