Introduction: Mont Blanc Ball Pen Refill Mods for Pilot G2 Pen
Picture of Mont Blanc Ball Pen Refill Mods for Pilot G2 Pen
Modifications to a Mont Blanc Ball Pen refill for the Pilot G2 pen.
Step 1:
Picture of
Open the Pilot G2 pen and remove the G2 refill. (Figure 2)
Step 2:
Picture of
Remove the plastic tip protector from the Mont Blanc ball pen refill. (Figure 3)
Step 3:
Picture of
Using a knife (or sandpaper) trim the three fins located on one end of the tip protector to be flush with the tip protector body. (Figures 4 and 5)
Step 4:
Picture of
Now cut off a 12mm section from each end of the tip protector to yield two 12mm sections. (Figure 6)
Step 5:
Picture of
Put the 12mm section that has an opening on both ends onto the ball pen refill. (Figure 7)
Step 6:
Picture of
Drop the remaining 12mm section into the top barrel of the pen. (Figure 8)
Step 7:
Picture of
Insert the Mont Blanc refill and reassemble the pen. (Figure 9 and 10)
annerjx (author)2016-05-30
This instructable is for the ball point pen refill not the gel refill. The ball point pen refill doesn't dry out.
SeanD87 made it! (author)2016-05-13
This sounds great, but don't waste your money on the Mont Blanc refill. Buy a G2 Pro, and be done with it. The Mont Blanc ink refills are designed to be capped, and will dry out if not capped. The G2 does not have a cap. My ink dried out in less than 2 weeks, and the original G2 ink is back in, and working great. The same thing happened on 2 different pens, 2 locations.
StevenQ1 (author)2015-03-16
I've never seen a hack like this. I simply cut off the rear end of the Mont Blanc refill to make it the same height as the G2 refill. What can I say? It's a bit rough, the clicker sometimes doesn't allow the tip to retract, but it works well enough. I definitely like it a lot. The Mont Blanc refill works much better than the G2. I get more resistance from the Mont Blanc refill which allows me that extra control to form my cursive letters better.
stangjr made it! (author)2015-01-04
best pen ever. I also used the old ink cartridge for both pieces. Good write up bro
kmathew92 made it! (author)2014-06-01
Awesome instructable! When I made it using the G2 casing, I found that using the Mont Blanc tip cover was kind of a tight fit. Instead, I tried cutting two 12mm sections from a G2 ink refill and it worked perfectly!
About This Instructable
28,044views
12favorites
License:
More by annerjx:Mont Blanc Ball Pen Refill Mods For Pilot G2 Pen
Add instructable to:
