Mood Cue: a Scientific Temperature- Mood- Correlation
Introduction: Mood Cue: a Scientific Temperature- Mood- Correlation
There are studies thats show that mood affects the body temperature of a person. This projects uses a temperature sensor to sense the body temperatures of a person and guess the corresponding mood.
Step 1: BoM
* Arduino
* Servo motor
* Temperature sensor - TMP36
* Popsicle
* Box
* Blade
* Glue gun and Glue sticks
Step 2: Making the Pointer
* Take a popsicle stick and begin shaving down the sides with the blade of an x--acto knife until you get an arrow-like shape. Roughen it up with an x-acto blade to increase surface area for glue bonding.
* Glue this pointer to the servo horn with hot glue.
Step 3: Wiring the Servo
* Connect the red wire of the servo motor to 5V.
* Connect the black wire of the servo motor to GND.
* Connect the white wire of the servo motor to pin 9 on the Arduino.
Step 4: Wiring the Temperature Sensor
* Connect the top pin of the sensor to 3.3V.
* Connect the bottom pin of the sensor to ground.
* Connect the middle pin of the sensor to pin A0 on the Arduino.
Step 5: Enclosing in a Box
Take the lid of a box and tape the Arduino on it securely. Then snake the wires through a notch. Add some paper and draw the different moods from sad to neutral to angry.
Glue the servo to the base of the box with the pointer pointing at neutral.
Step 6: Coding and Uploading
Upload the following code to the Arduino.
#include <Servo.h>
const int servo = 9;
const int tempPin = 0;
//raw reading variable
int tempVal;
//voltage variable
float volts;
//final temperature variables
float tempC;
Servo servo1;
void setup() {
  // put your setup code here, to run once:
void loop()
 //read the temp sensor and store it in tempVal
 tempVal = analogRead(tempPin);
 //converting that reading to voltage by multiplying the reading by 3.3V (voltage of       //the 101 board)
 volts = tempVal * 3.3;
 volts /= 1023.0;
 //calculate temperatureňú celsius from voltage
 //equation found on the sensor spec.
 tempC = (volts - 0.5) * 100 ;
 if (tempC <28)
  servo1.write (80);
 else if (tempC <30 && tempC > 28)
  servo1.write (100);
 else if(tempC<36 && tempC>31)
 //wait a bit before taking another reading
    • Epilog Challenge 9
      Epilog Challenge 9
    • Paper Contest 2018
      Paper Contest 2018
    • Pocket-Sized Contest
