I am in the process of designing all the lamps and lights in my house. For my living room I wanted to create a nice mood light. Its a little bit inspired by the commercial available mood lamps with my own personal touches. The final result is a bowl that can stand upright or its a side on the floor or on a table.
This mood bowl is great in the living room and creates a nice ambiance. You can choose your own color / mood for a movie, a dinner or a party with friends.
The LED controller I used has sixteen different colors and four different modes (flash, strobe, fade and smooth). You can adjust the brightness as you like.
With the right materials and tools on hand this mood bowl is relatively cheap (30$) and easy to make.
Remove these ads by
Signing UpStep 1Materials and tools
Materials:
- LED controller
- Approximately 1,5 m RGB LED strip
- Window foil
- Clear acrylic sheet
- 2 screws
- 12v power supply 1.5 amp
- Wooden board (MDF) 18 mm thick
- Steel sheet
- 4 5 mm by 5 mm magnets
- 4 hex nuts
- Paint
Tools:
- Wood glue
- Super glue
- Jig saw
- Wood file
- Sand paper
- Wood clamps
- Drill
- Drill bit 6 mm, 10 mm
- Hole saw 90 mm
- Solder
- Solder iron
- a pair of compasses
- paint brush
then buy a cheap lamp from target
http://www.target.com/p/Room-Essentials-Desk-Lamp-Black/-/A-12227096
then get a bowl
After that mod the lamp to your liking, put the bulb in the lamp, then shove it in a bowl
Total price 50 bucks
only incredible
it has to be superb
where did he get the control from I might want one too.....
Just sand with a small grid and you get clean results.
