This filter can be used to clarify and purify moonshine (which is ethanol), in order to be use as fuel for mini stoves, lighter fluid, or even causing a warming sensation if consumed.
It really doesn't matter what color your moonshine is, or what it smells like, or even if there is crap floating around in it. You SHOULDN'T be drinking it. If for some God forsaken reason a sip or two accidental managed to plunge down your throat, it would be less disgusting having been previously filtered.
DISCLAIMER: I take no responsibility for anything whatsoever that results in the following of this instructable. Moonshine is illegal to distill and not intended for human consumption. This how2 is simply how to filter out any odors particles and abnormal colors.
Remove these ads by
Signing UpStep 1Supplies Needed
-Soda bottle
I used a water bottle for demonstration, but soda bottles have a convenient blue seal on the inside of the lid which keeps everything in place. You can use an any size bottle that you want. Bigger bottles will be able to hold more moonshine to be filtered, so that you do not have to constantly fill them up.
-Coffee filter
You just need a piece the size of the bottle's cap
-Activated Charcoal
This is stuff that you are supposed to put in aquarium filters to remove organic odors and colors. If is clean and safe enough for your pets, why not use is for moonshine?
Have a look around http://homedistiller.org/ if you haven't already been there
But they don't like talk of using plastic in the distilling process.
