3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Moose/Bear Repellent aka FLAME THROWER
The idea for this project was born from trying to get our campfires started with kindling and wood so wet we couldn't get them to burn with dry paper. Sure charcoal lighter would work but where's the fun in that?
Please don't be misled by the term Moose/Bear Repellent, I only used it to create more interest. It probably wouldn't deter a bear that was intent on inflicting harm. If anyone wishes to visit Alaska to enjoy the great outdoors, I would recommend some sort of bear deterrent. Be advised a big ol' can of pepper spray isn't always effective, they have even been seen licking it from the ground. Making plenty of noise or an occasional blast on a portable air horn while you're hiking will keep surprise encounters to a minimum. As for the moose, beware, they usually aren't afraid of anything and would love a chance to bully you for your snacks, or for no reason at all.
Some words of caution: Be safe, have a fire extinguisher or bucket of water nearby and someone else there in case whats burning is you. Never operate indoors. You wouldn't pee up a rope or spit into the wind, it'll get ya if you do, so don't use it when the wind is blowing.
Materials: All materials are available at Lowes or Home Depot except the butane refills and birch plywood, which can be found at tobacco shops and craft stores respectively. Total estimated cost $50-$60 US.
8 in. of 1-1/2 in. type "L" copper tubing
1-1/2 in. copper end cap
1-1/4 in. copper end cap
1 in. length of 3/4 in. soft copper tubing
1/4 in. x 1-3/4 in. hitch pin
4 in. x 4 in. x 5MM extruded acrylic
24 in. x 12 in. x 1/8 in. birch plywood
1-1/4 in. length of 1/4 in. oak dowel
1-1/2 in. x 1-1/8 in. x 1/2 in. long aluminum angle
4 pcs. 1/8 in. tension pins 5/8 in. long
12 pcs. #8 x 3/4 flat head wood screws
3 pcs. #6-32 x 1/4 in. flat head machine screws
1 pc. #8-32 x 1 in. flat head machine screw
2 pcs. #6 x 1/2 in. flat head wood screws
1 pc. #8-32 x 1/4 in. flat head machine screw and lock nut
1 pc. #10-24 x 3/8 in. pan head machine screw, flat washer, lock washer and nut
pulse ignition for gas grill with wiring harness ( Lowes or Home Depot )
1 pc. AA battery
2.1 oz. can butane
1 paper clip
1 pc. 3/4 in nylon pipe cap
Titebond wood glue
super glue
a bit of solder
Tools used:
Laser cutter
Pipe cutter
Hand drill and assorted bits
Dremel with cut-off wheel and drum sander
Wire crimper
Sand paper
Scotchbrite
Propane torch
Router table
Phillips screwdriver
Below are the drawing files for the grip frame.
Step 1Choose the fuel supply and material for the fuel chamber
PIC#1 I chose to use a 2.1 oz. can of Bernzomatic butane because I already had it on hand.
PIC#2 I checked a copper tubing handbook and found the size of copper tube that's inside diameter most closely matched the outside diameter of the butane supply I was using, which happens to be 1-1/2 inch type "L" tubing. I cut an eight inch length of the 1-1/2" type "L" copper tubing. I Purchased a 1-1/2 inch end cap to fit over one end of the tube and another 1-1/4 inch cap to fit inside the tube.
PIC#3 The end of the nozzle on the butane supply is stepped.
PIC#4 A hole for the butane nozzle must be placed in exact center of the 1-1/4 inch end cap. To find center I painted the inside of the cap with a black marker and allowed the ink to dry.
PIC#5 Coiled up scotchbrite pad rotated gently inside the 1-1/4 inch cap to remove the ink.
PIC#6 If done as described you should have a mark dead center. Drill that mark with a 1/16 inch bit followed by a bit just large enough for the butane nozzle to pass through until it contacts the first step on the butane nozzle.
114 comments
1-40 of 114next »
May 1, 2012. 10:28 AMmamajr96 says:
About how much did everything cost?
Mar 12, 2012. 5:26 AMxSmok3y says:
what is the scale for the pdf file? I need it for my lazer cutter. Thanks!
Mar 2, 2012. 9:05 AMBlaise_Gauba says:
Very nice work. Very Steam Punk looking. The copper tubing probably gives it some weight whereas I might consider using PVC. Do you think that that would be a melting hazard? Anyway, I read all the way through your Instructable and found it very thorough except I ended up becoming a bit lost with the soldered fuel chamber with the nylon end-cap. If I may be so bold as to ask, what is that chamber for again? And, do you have any photos of that chamber taken from a 3/4 view so we can get a visual perspective of it? As it stands though, I love it and it seems like a fun enough project to take on. Be safe and responsible folks. :-)
Feb 27, 2012. 12:08 PMantoon says:
really cool but i have no way of making it :(
creddits to the maker
Feb 3, 2012. 3:41 PMFootball viking boy says:
Great job! I've been looking around for instructions to a flamethrower. This is really great but I might need to simplify it.
Jan 26, 2012. 9:51 PMmoneyfuskie935 says:
All I can say is... WOWZA!!!!
Dec 18, 2011. 7:01 PMbroken-feather says:
Very well thought out and I do believe it could be a formidable deterrent for lots of situations. Gob well done. I like it.
Dec 14, 2011. 8:12 AMSeveran_Mal says:
Lol love the title and vid!
Dec 1, 2011. 3:16 AMarchieburden says:
its all good until it blows up in your face...
Nov 28, 2011. 3:28 PMhossweightlifter says:
This is amazing.........
Nov 19, 2011. 10:27 AMFriendOfHumanity says:
Wow! That's a great instructable.
You have created a thing of beauty.
Nov 28, 2011. 2:13 PMdtaylor27 says:
? sad
Whaat??
Nov 15, 2011. 5:05 AMSergei- says:
Hi
Thats awsome
I have some similar plans that i baught at an online book shop that use to be in australia about 15 years ago
Turns out these plans are from the information unlimited people and this book shop was selling a cd's worth full of things like this
That looks great can't wait to look more closely at it
Serg
Nov 22, 2011. 4:00 PMSergei- says:
hi
The place i got the cd from has closed down but i can give you the site that origonaly had the plans for sale but they sell them at different prices and it's full of things like kits for things not just the plans/schematics
http://www.amazing1.com
They have all sorts of cool stuff there
Serg
Nov 22, 2011. 5:27 PMilpug says:
This is amazing, if a bit complicated for me.
If you put this in your pocket, it might be considered a concealed weapon, as this is probably extremely illegal.
Does this have a safety?
Nov 22, 2011. 6:55 PMilpug says:
Yeah, true. Anyway, great design and build!
Nov 20, 2011. 1:16 PMprofessor awsome says:
Perfect, bring it on zombies! im ready for ya now
Nov 20, 2011. 9:15 AMtheguyhere says:
That amazing... Now get a bigger spray can and make a bullpup rifle :P
Nov 15, 2011. 5:21 PMdeobomb says:
would wood work for the triger and push rods?
Nov 15, 2011. 1:13 AMbatonas says:
nice design man
Nov 15, 2011. 2:45 AMkibukun says:
Hmm, Bear deterrent? like a shotgun?
Nov 8, 2011. 2:06 PMprofessor awsome says:
Isnt it illegal to own a flame thrower?
Nov 14, 2011. 3:43 PMzebede5 says:
In the United States, there is actually no law that says that you can't own a flamethrower.
Awesome......
Nov 11, 2011. 5:45 PMwobbler says:
Isn't it illegal to own anything that's fun? That makes this definitely illegal. As for the "gun" debate, it's how you use them. I've got a glue gun and I've not killed anyone with it yet, although it has got me into some sticky situations.
Nov 12, 2011. 7:24 PMprofessor awsome says:
AWW (%^&* im so scared now
P.S. Were is podunk so i can officially measure how terrified i should be of this heavily armed bank robber
Nov 12, 2011. 7:09 AMfidgety2 says:
Oh so true I myself have often found my glue gun to be more useful than my dremel but never my beloved leatherman
Nov 10, 2011. 9:22 AMRichardBronosky says:
No. They are often used for weed removal. In fact you can rent them from tool rental places. Or buy them from places like Harbor Freight.
http://www.harborfreight.com/propane-torch-91033.html?utm_medium=cse&utm_source=googlebase&hft_adv=40010&mr:trackingCode=A8720F9E-782A-E011-B31E-001B2163195C&mr:referralID=NA
http://www.nextag.com/weed-flame-thrower/shop-html
1-40 of 114next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
39
Author:PDRWLSN
