Step 3Building the grip frame
PIC#2 Glued it all up with Titebond wood glue. Held the pieces in alignment with 1/8 inch cotter pins and spring clamps until the glue set.
PIC#3 The right side frame is glued up from three layers, the left side eight layers. This facilitates easy disassembly and reassembly. The 1/4 inch oak dowel was cut slightly long to be trimmed after final assembly. Also the dowel is only glued to the left side. Both sides were held together while the glue set to hold the dowel in alignment.
PIC#4 This picture shows the placement of the cotter pins used to hold the left and right sides together as I rounded the right side edges( bottom) on the router table. Used a 1/4 inch round over bit.
PIC#5 This shows the completed grip frame assembled for the first time. I used #8 x 3/4 inch screws.
PIC#6 I drilled a 1/8 inch diameter hole in the center of the grip frame and glued a 1/8 inch diameter x 3/4 inch tension pin to engage the mounting boss soldered to the fuel chamber.
PIC#7 I cut a 1/2 inch long piece of 1-1/2 inch x 1-1/8 inch x 1/8 inch aluminum angle to secure the rear of the fuel chamber to the grip frame. Drilled two 1/8 inch holes through the 1-1/8 inch leg 1/2 inch apart and attached to the grip frame with two #6 x 1/2 inch wood screws. Then measured to locate the hole for the pin which protrudes through the rear of the fuel chamber and grip frame and drilled a 3/32 inch hole at that location.
Add Comment
